f**k the spectators !
when your on the track you forget about em anyways
first time i was out i was like ''OMG OMG OMG OMG OMG'' then after a couple laps i was chilled
crankin some beats while your in line waiting to have a run chills ya out
after a couple of times going around and just doing some clutch kicks i was entering corners on the handbrake ;)
you think its gonna be nerve racking but its not after a few laps :P
  • Replies 14.2k
I'm not too sure yet man. I've got my eye on a few cars but ideally it'll be something 'S' chassis so S13 or 180sx mainly because their is epic amount of parts available for these, cheap, and I love the styling of them. Smashed up pig S13/180 is hot lol aswell as a clean streeter with outrageous fitment.
Did it take you a couple of laps to get into the swing of things, like basically not sliding the first few laps?
Be good for the first timers if they let us just lap the track a couple times just to get the feel of the track
yeah man, just drive a lap normally, then just clutch kick OUT of corners to get a feel of things
anf before you know it, you will feel at home
next prac will be my first with a handbreak, so will be new beginnings for me aswell
yeah man , just took it easy and got a feel for the track
if theres one thing i learnt , its that mallala is slippery enough in the dry , let alone the wet !
i wanna head out saturday but cant afford to , ill be at the next prac fo sho if i still have my car !
Wayne try and get into a drift school when they have them.
I'll be buying a slider next year I reckon hehe
Yeah man, I do intend on attending one of them courses but the next one isn't untill October and I want to start sliding before then lol
I'll probably be out at the skid prac in August
If there is a private grip day before then I'll even go to that, i don't care what I do, I'm racing haha.
I'll even drag race the cvnt if we had a track in Adelaide :P
grip days are before drift prac
ie in the morning ;)
Don't they hold alot of motorcycle events during the day? I'm more interested in a private day. When is SAU:SA holding another event?1?!?!?!?!??!?111oneeeneeeeOMFG!!ZOR1!!!1
every now n then
im also keen for a private grip day!
every now n then
Keep ya skirts on people ... an announcement will be made soon on the next track day when we can work out a date that doesn't clash with other events (by either SAU-SA or another party). :P
quick !
before my Nissan disappears !
they dont have to go hammer and tongs, and adrift day is limited to 10 spots
surely theres ten people with some sort of testicles in there pants
Just bear with me for a bit. I'm sussing out another option. Holding a drift day for 10 entrants gets heavy on the cash for the entrants. I may have a cheaper option in mind. Need to discuss with the Committee first.
:P
Had I a car to drift with, I would be out there. Give me yours and I'm down like a clown :P
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
