All too true. It can happen to ANYONE.
Few people have been around a fatal accident. Even fewer having to hold and comfort the poor soul as they passed. Its something you certainly do not forget.
i agree.
Been there, done that.
  • Replies 14.2k
http://cgi.ebay.com.au/ws/eBayISAPI.dll?Vi...T#ht_521wt_1137
i really f**king want...
god dammit i wish i didnt see it!!!!!!!!!1
http://www.nissansilvia.com/forums/index.p...howtopic=451965
I've been eyeing it off for awhile as well.
Been dissapointed at all the cars I've been looking at, but this is cheap. Only think stopping me is it beeing in Vic and I dont know if I have time for it yet.
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
