Righto,
I'm expecting a few varying opinions on this but what is the best way to run in a new engine. I've just had mine rebuilt and am about to run her in. The engine is cranking over and is already fully lubed so i don't need any info on that.
Cheers!
https://www.sau.com.au/forums/topic/29184-running-in-a-newrebuilt-engine/
yeah, i bought running in oil - full mineral that's only good for 500 kms. used a special bottle thingo and an air-compressor and pumped oil up through the galleries so it was fully lubed before it started.
You have any suggestions for running it in Sydneykid? ie, nurse it, flog it, vary rpm, long constant rpm drives, stop start work, low speed/high gear, hill climbs?
In my experience i have been told to give the engine some good load at low to medium RPM to help with bedding the rings in, obviously high RPM is bad as is high boost. Mineral oil is advisable for the first 1000k and then it's time to go nuts :crazy: This information was given to me when i rebuilt my first engine about 12 years ago by a family friend who was a touring car mechanic and it worked for me.:rofl:
Run low boost, bring it on load, dont rev it off its t!ts, stop start driving, varying the revs alot (city traffic driving is good) dont let the car idle too much, dont do freeway running in, drive up a mountain road, change running in oil @ 500kms, then service @ 500km intervals till 2k.
Rev the tits off it! Well, kinda. Have a read of this article. It makes sense, and I think I'd like to do it to my engine come rebuild time. But the guys at Bel Performance got really upset at Tony just for driving his rebuilt car sedately around the car park, and it was enough to make me think twice about the procedure.
I dunno, after reading it again it still makes sense. I think I'd do it. If you try it, let us all know how it goes.
Hopefully I won't need a rebuild for quite awhile. The engine's done >100k km and there's not even any blow-by in the oil catch can lines after 1000km from when it was installed. I think the only things that'll make me need one are a failed ringland or spun big end bearing.
[disclaimer: I'm not responsible if it kills your engine! :) All I can say is that I think I would do it myself]
Edit: when I broke in the engine on my new motorcycle 2 years ago, I couldn't resist the temptation to open it up every now and then within the break-in period. It didn't do anything strange, like no weird losses of power or overheating, and no weird noises. So I'm pretty sure it would have been ok to follow the above procedure, if I knew about it at the time.
Hey there.
I beleive the best way to run an engine in is high load, low revs. Load pushes the rings outwards, giving good bedding conditions.
Revs is what ruins new engines, not load.
BASS OUT
Bass Junky:- Cheers dude. I think that's what will be done.
HIPSI - Yep, forgies are in and swinging. Sounds great. In my opinion, impossible to hear "piston slap". Love it.
JimX - No offense dude, but i never thought rev'n the tits of it was ever an option. Boost can't be great for a new engine as RSN11Z said.
I think my engine will see some mild work, low throttle hold in gear (to about 4.5 - 5K) acceleration, high load/low revs.
All I have to say is it's sweet to have it back. Thanks everyone for their input.
    • Has equal chance of cleaning an AFM and f**king an AFM. I think you can work out what happened. When the Hitachi ECU sees the AFM die and goes into the associated limp mode, then it will start and run just fine, because it ignores the AFM and just runs on idle maps that will do what it needs to get it going. But there is no proper load signal, so that's about all it can do. My suggestion? If you don't want to go full aftermaket ECU, then get some R35 GTR AFM cards and some housings to put them in, in the stock location, and Nistune the ECU. Better to do a good upgrade than just replace shitty 40 year old tech with the same 40 year old tech.
    • So my car was recently having trouble starting on initial crank, I would need to feather the gas for it to start up but besides that it would start and run fine. So I clicked the idle air control valve (with throttle body cleaner) and cleaned the MAF sensors (with MAF cleaner). The start up issue was fixed and now the car turns over without the assist of the throttle, but the car is in limp mode and wont rev past 2.5k RPM. From what I understand the IACV would not put the car in limp mode, so I am to believe it is the MAF sensors, but it was running fine before and now I cant get it out of limp mode. I cleaned the MAF made sure the o rings were seated properly. Made sure the cables were plugged in properly, the cables also both read the same voltage. Does anybody know why this is or what could be causing this or how to get it out of limp mode?
    • Ooo I might actually come and bring the kids, however will leave the shit box home and take the daily
    • Thanks. Yeah I realised that there's no way I'd be able to cover the holes with the filler, it would just fall through. Thanks again @GTSBoy!
    • That was the reason I asked. If you were going to be fully bodge spec, then that type of filler is the extreme bodge way to fill a large gap. But seeing as you're going to use glass sheet, I would only use that fibre reinforced filler if there are places that need a "bit more" after you've finished laying in the sheet. Which, ideally, you wouldn't. You might use a blob of it underneath the sheet, if you need to provide some support from under to keep the level of your sheet repair up as high as it needs to be, to minimise the amount of filler you need on top. Even though you're going bodge spec here, using glass instead of metal, the same rules apply wrt not having half inch deep filler on the top of the repair. Thick filler always ends up shitting the bed earlier than thin filler.
