hay guys
i currently have the jjr (just crap racing) front and rear strut braces on my car and i wantr to change them to something good.
now i have a cusco rear one on the way but for the front i want one of those big f**k off thick ones like u see on gtr's but i cannot find one anywhere i know that it wont clear the plenum but i have a plazma man going on soon so not rally worried about that
cheers
julz
https://www.sau.com.au/forums/topic/291934-strut-brace-question/
I'd say he would, but I think this is a case of form over function.
Get a price to get one fabbed up....it is after all....just a brace.
You've got the JJ one to go off as a template anyway. Just a thought. At least then you'd have one of a kind
+1
sounds like a good idea to get one made up.
the jj one is so shit it touches the top of the plenum of the stock rb25 and i think the bonnet as well coz it has scratches on it at the top and i dont know where from.
yes it is just for looks really but i think that i will notice some difference in the way it drives too
they don't serve that bigger purpose on the skylines anyway due to the way the suspension is setup, compared to silvia's etc that rely on the top of the strut more
so no, he won't see alot if any difference driving
if it's rubbing on stuff etc then get a new one, i was considering getting a JJ front one but if they rub on stuff i might look elsewhere
the rear ones are pretty much completely useless in skylines
no way in the world will you feel any difference between brands of strut brace. In fact odds are if someone took it off and didn't tell you, you wouldn't pick it at all.
unless you mean a difference in how your wallet feels?
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
