Housemate is getting cranky with car parts sitting in the lounge room so clearing the stuff that I don't really need. Willing to post any items, buyer pays post.
Items are all located in Geelong (3220)
Part of a Tomei 3 part strut brace. **Note that this is only one part** (See pics below)
$150
Apexi Boost guage - works perfect and glows blue. Removed to replace with another item I had
$60
Clear passenger side indicator*
$45
Orange drivers side indicator - slightly faded*
$30
*Please refer to pics, as clip is broken on both indicators.
Cheers :)
Edited by stealth-ish
https://www.sau.com.au/forums/topic/291974-r32-brace-indicators-boost-gauge/
GAUGE is GONE
forza5, ill send you a pm tomorrow as i'll know for sure if its sold or not
do you think you could post your number here? i havnt made 10 posts yet and cannot check my inbox at this time.
i can pick it up asap
ahh need that driver side indicator send me your datails
cheers
pm sent
I will get back to you later this evening, pending if i hear back from another member. Have you got an email address i can catch you at otherwise?
keen on clear indicator if you have a pair???
I dont have a pair sorry. otherwise as per above if i dont hear back from another member forza5 may get it.
first in best dressed guys!
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
