FOR SALE !!!!!!!!
FRONT MOUNT INTERCOOLER
TEIN FULLY ADJUSTABLE COILOVERS
SLOTTED ROTORS FRONT & REAR
20'' RIMS 90% TREAD
AUTOMETER BOOST GAUGE
NISMO GEAR KNOB
TURBOSMART BOOST CONTROLLER
EXHAUST FROM TURBO BACK
HKS POD FILTER
BOSCH 500HP FUEL PUMP
NISMO 300KMH DASH CLUSTER/ READS 90000KM
DRIVERS BUCKET SEAT/ STANDARD PASSENGER SEAT
CD PLAYER
FRONT BAR PLASTIC WELDED IN CENTER/ NUMBER PLATE MOVED
MOMO STEERING WHEEL
JJR COILPACKS
ALARM SYSTEM WITH LOTS OF FEATURES/KEYLESS ENTRY/INBUILT TURBO TIMER/REMOTE START/STOP/ELECTRIC WINDOW LIFT
5% WINDOW TINT ON SIDES. 15% ON REAR
TIMING BELT REPLACED 10000KM AGO
REGO TILL 27/04/10
LOCATED HILLS AREA IN SYDNEY
THIS HAS BEEN MY PRIDE & JOY FOR THE LAST 3 YEARS I WAS THE FIRST AUSTRALIAN OWNER & WILL BE VERY SAD TO SEE IT GO BUT ITS TIME TO MOVE ON. THE CAR HAS SOME MINER SCRATCHES BUT NOTHING MAJOR, THE AERIAL NEEDS REPAIR BUT RADIO STILL WORKS FINE, IT HAS HONESTLY BEEN A VERY VERY RELIABLE CAR, REGULARLY SERVICED & WELL LOOKED AFTER SINCE I HAVE OWNED IT.
PRICE $15000ono
ANY QUESTIONS PHONE STEVE 0418549870
MORE PHOTOS POSTED SOON.......................
Edited by 666666
https://www.sau.com.au/forums/topic/292147-r33-gtst-series-2/
Where is it located?
How many k's do u think is on it? As you said the dash states 90,000k's.. how many k's did it have when imported?
Anything extra with sound system? ie. cd player. please specify
STILL FOR SALE GUYS!!!!
Judging by the interior i would say it was close to what the dash reads, but to be honest there is no way of knowing what the japs did to it before they shipped it over. Car had 70000km when i recieved it & i was the first aussie owner!!
Located near parramatta in sydney.
Yep it has a cd player with aftermarket speakers in the doors and rear parcel shelf, with cable to plug into ipod & ipod holder.
Selling because i always wanted a V8, no swaps as my V8 is already parked in my driveway!
I am a mechanic by trade and have looked after this car ever since owning it.
This is a very clean, respectable looking car, all inspections welcome.
Edited by 666666
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
