R34 gt silver sedan, RB25de neo, came from japan auto so i changed it to manual, the car has done 125,000kms and the clutch and box and tail sharft have done 45,000kms! over all the car is in good nic! runs like a dream! very hard to find the n/a 4door in manual! i have never seen one! it really is a great p plate car!
Rego till feb 2010, comes with rwc, car is very good on petrol, gets 450-500km's a tank.
what i have done...
front summit strut bar
front and rear redline sway bars
hks coilovers(one needs rebuilding)
2 1/2 inch all the way though(comes with stock one)
high flow cat
cannon muffler
custom made extractors
GTT turbo diff
r32 gtr wheels(comes with stockies)
3A racing pod filter
dvd head unit
8 inch sub and amp!
brand new splitfire coilpacks
brand new o2 sensor
drift gear knob
eye lids
manual conversion:) best mod ever!!
still has the auto steering wheel on! but i have a nardi that ill chuck in, it comes with boss kit!
its had its 100,000kms service all belts and fuilds everything done! Just had new premium spark plugs put in at last service! car is serviced every 8000 to 10000 kms being n/a! reason for selling.... just want a turbo, will trade for a R32, R33 GTST with cash my way.
looking for about $14500 neg! im in vic, hallam! pm me!
https://www.sau.com.au/forums/topic/292206-r34-gt-4door/
what i have done...
high flow cat
cannon muffler
GTT turbo diff
dvd head unit
8 inch sub and amp!
brand new o2 sensor
drift gear knob
eye lids
it looks pretty decent
https://www.sau.com.au/forums/topic/292206-r34-gt-4door/#findComment-4883551
4door n/a in manual are so so hard to find and all the money i have put into it. dont think i am pushing it, the stock auto's go for about 11, 12. but yeah thanks for your input champ
https://www.sau.com.au/forums/topic/292206-r34-gt-4door/#findComment-4912361
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
