  • Replies 42
Hey guys, i am about to part with the folding stuff for one of ray hall's Vi-Pec plug in ecu's for my gtr but i am having trouble getting feedback for the plugins. Anyone here used them? experiences ect, help an old guy out!
Cheers allan
Ive got one in my 34 and I love it, im not much of an ecu expert but Im really happy with mine.
They've got some good features and the fact that they dont need afm's is great :)
https://www.sau.com.au/forums/topic/292301-vi-pec/#findComment-4884869
Im doing some research on ECU's and found mark from godzilla to be very helpful with all my inquiries about the Vi-Pec....from all reports including people using them over in canada they are a great ECU and good value for money, im planning on coupling mine with one of the ruzic engineering displays.
https://www.sau.com.au/forums/topic/292301-vi-pec/#findComment-4884895
Vipec / Link are an amazing ECU for their price, I wouldn't put anyone off them.
I have seen eight second cars and the Vipec controlling 8 x 1600cc injectors perfectly.
Mark and i installed a Vi-PEC in Tony Wedlock's Solara drag car its has 18 x 1600cc injectors and runs 6.6's.
I run a Vi-pec ecu in our 9.45 sec GTR street/drag car as well as our street/circuit GTR. Both of these cars are tuned by Mark Jacobsen at Godzilla Motorsport....simply awesome results.
https://www.sau.com.au/forums/topic/292301-vi-pec/#findComment-4885892
wow enough said
go to mark at godzilla
/thread
https://www.sau.com.au/forums/topic/292301-vi-pec/#findComment-4885900
Are you talking about the Gas Motorsports Solara?
If so who did the tuning for that, was it Phil Laird, Joe Signorelli or someone from titan or elsewhere?
https://www.sau.com.au/forums/topic/292301-vi-pec/#findComment-4885937
No...Tony Wedlock...TRD Aurion its called now, its a bit hard to get the Solara name out of my head. Its the ex Matt Scranton car from the states. It runs a V88 Vi-PEC with the 18 injectors squirting methanol, twin M&W drag 6 cdi's, M&W coils and an AEM wideband controller.
Mark actually did the initial tune on his chassis dyno and further tuning was done after each run at the strip using the data from the logs. Running a methanol car on a chassis dyno in an enclosed environment was no fun...it took days for my eyes to recover.
Edited by DiRTgarage
https://www.sau.com.au/forums/topic/292301-vi-pec/#findComment-4885970
yeah, mackeye is still 5hrs away tho lol. we have recently got a 4wd dyno into town but i dont trust one of the tuners:(
Simple...arrange to hire the dyno from the owner and fly Mark up for the day. This is how we get him to tune our cars down here. Maybe organise another car to get done as well and share the cost between you and them.
https://www.sau.com.au/forums/topic/292301-vi-pec/#findComment-4887292
Well, after working it out, hiring the dyno for 8hrs at $165hr, return flights to sydney at $849.70 and the cost mark will charge its gonna be a real killer. Im actually located in Gladstone, Central queensland, smack in the middle of everything lol Just weighing up the option of putting it onto a truck and sending it somewhere, to get it to brisvegas is gonna cost me 741 smacko's one way inc insurances. Still waiting on how much to get to other places
https://www.sau.com.au/forums/topic/292301-vi-pec/#findComment-4887315
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
