hey fellas, just had my car serviced / fluids changed and a new clutch put in..
previously on the oil temp guage the thing sat barely above the 70 line.. however last night i was driving it for about 15-20 minutes, without revving it over 4000rpm, but was driving it fairly quickly (well as quick as you can without revving it out anyway).. and after the drive i noticed the oil temp had gone to 1/4 where i've never seen it before..
i have no idea how accurate that gauge is, but i'm more concerned that it's now got to a higher level than i've seen it before..
the oil was changed with the same stuff as it was running before (motul 300v 15w50)
any ideas?? or am i just being paranoid
Edited by ohno1
Was the thermostat changed? If so the oil temp becomes the same temp as a water because of the OEM oil cooler... it's possible the old thermostat opened fully at alittle over 70c, whereas the new one opens fully at about 82c?
factory oil cooler cools (and warms when cold) the oil with the engine's coolant. If the coolant is 82c, the oil temp will sit about afew degrees higher unless driving at the track or driving it hard the oil temp will become alot more hotter but coolant temp will stay the same.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
