The request for the cops details would be seen as a threat of action against him, of course he is going to go harder on you. I mean why not, if all you are going to do is complain about him, he might as well sting you for everything he can.
As stated previously you have every right to request officer's name, station and registered number. I only advised that It wouldn't be in your best interest as in most cases you will get much more harder treatment. If I thought that someone was going to complain about me I would give them every fine, charge, NOU EPA under the sun as it would look much better for me if you did complain. As then I could say they complained becasue of all the fines, NOU etc.
If I was stupid enough to pull someone over and abuse the crap out of them and not give them anything and they did complain it wouldn't look good for me, because why would someone complain if they received a warning or routine intercept?
    • Literally looks like direct port nitrous haha
    • They are in fact just nozzles. They are there only to produce a spray pattern and limit flow. The injector itself is what I use to control flow to the 7x nozzles. My old system had no injector and only PWM the pump. This lead to a lot of inconsistencies, and poor atomization at low pressure when the pump was ramping up.
    • With the system, once you drive it for a bit, and before you turn the car off, does the car fix its date and time? When you say the date is wrong, what date does the vehicle think it is, and does it always show the same date? My thoughts from a process driven view is; The system may be defaulting to a standard start date/time. The main reason you'd typically see this occuring, is the system is losing its constant/backup power supply.   If its always defaulting to the same date/time at start up, and especially if it fixes itself while driving, I'd say either the non volatile memory has an issue, or the power supply to the volatile memory that stores this information.   The other thing I'd check is if there is anywhere in the system you can adjust the date and time from. If the date/time is still moving forward since it wished you happy new year, then it is 100% possible the system has just had a bit of data corruption occur, and you likely need to find a way to reset the date/time in the vehicle.
    • Scissor Jacks are an accident waiting to happen, the only time they should be used are in an roadside flat, even then a tyre and rim should be placed underneath
