Item: 1995 R33 Nissan Skyline :banana:
Website: booost!
Item Condition: Immaculate, small paint imperfection on rear bar (drivers side), interior cleaner than any r33 i seen! has all original nissan skyline motorsport floor mats and all!
Reason for Selling: too many cars, & it driven rarely!
Price and Payment Conditions: $12,000ono cash only atm no swaps plz!
Extra Info:
series II rb25det (great condition - starts quick and idles beautifully) - always serviced every 5,000k's
automatic gearbox
silver in colour
has just had 6 months rego paid and RWC will be supplied upon sale!
- Freshly painted bonnet
- New hood lining
- New SCA battery
- Apexi Full Time- for turbo & NA
- HKS - FMIC, piping (painted same as car), HKS blue silicone joiners. <- still has full reo bar and thermo fan!
- Customised series 1 front bar
- 3" cat back exhaust system (good note!)
- Chrome headlights (rare)
- Side skirts
- Blue LED dash with white faced dials (can change lighting in cabin)
- Sony Xplode head unit and speakers
- KnN pod filter with adaptor
- New castor rods
Pictures: yes! :P
Contact Details: Hamish R Dawson; ph: 0419761510 (text or call) , [email protected] (email or msn), PM
https://www.sau.com.au/forums/topic/292532-r33-skyline-s15/
Able to get some pictures?
No worries mate! i thought there were already photos up! :P here they are! :D - they are taking a while to load, i have more so if you want to see them pm me and i'll email them all to you :banana:
also forgot to mention in first add the additional features of:
- 4 wheel disc brakes
- Adjustable Steering Column
- Air conditioning
- Aftermarket 18” alloy wheels with chrome lip
- Auto Climate control unit
- Central Locking
- Aftermarket alarm and immobiliser system
- CD player
- Electric Mirrors
- Direct Fuel injection (340cc)
- Power Steering
- Power windows
- Tilt Steering
- Tinted Windows
:D cheers, hame!
https://www.sau.com.au/forums/topic/292532-r33-skyline-s15/#findComment-4946991
  • 4 weeks later...
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
