UP for quick SALE:
Item: OEM R34 GTT/R Xenon Headlights
it's a Genuine R34 Xenon with Adjustable Heights
Condition:
- Immaculate Clear Cover
- No Broken Brackets
- Original cables
- NO XENON Bulbs & Ballast (They're already dead)
- High Beam Bulbs still available
- Never had any accident involving the headlights
- Normal Wear & Tear ( some scratch from small rock on the roads, normal driving though, its an N/A)
- NO LEAKING Water going inside! so no fogs inside the headlamps
nb:
CAN supply u with used aftermarket Xenons (which i currently use for the xenon headlights) for $100
Item Location: Canberra, 2617
Postage: Rough estimation: $50 to Perth in 5 business day.
- Anywhere at buyers cost.
- Able to pick up only as well
- Packed in a tight box and cover it to avoid scratch
- AusPost or anything as buyer's request
Reason to sell:
- Have another project with Xenon Projectors
Price: Reasonable $800 considering it'll cost u $1K everywhere. FIRM!!. Try Ebay and u'll find these things for $1200.
- Dont tell me stupid things like "u can get it cheaper from importmonster etc2." well go for it then, its gonna be more expensive since u need to pay import duty as well.
- I'm Putting this on Ebay as well, so u guys have to compete with ppl around the world. But, to be honest i prefer Australian buyer (less hassle, more comunication). http://cgi.ebay.com.au/ws/eBayISAPI.dll?Vi...9#ht_500wt_1182
PLEASE no LOW-BALLERS, i'm trying to do SMOOTH and NICE business here. not playing around.
Contact Person:
- SMS (24/7): 0420905342
- Call (certain times): 0420905342
- E-mail: Putraged(at)msu.edu
11 Actual Pictures of the Item:
Edited by putraged
    • AHHHH gotchaa, I'll do that once I am home again. I tried doing the harness with the multimeter but it seems the car needed a jump, there was no power when it was in the "ON" position. Not sure if I should use car battery jump starter or if its because the stuff that has been disconnect the car just does send power.
    • As far as I can tell I have everything properly set in the Haltech software for engine size, injector data, all sensors seem to be reporting proper numbers.  If I change any injector details it doesnt run right.    Changing the base map is having the biggest change in response, im not sure how people are saying it doesnt really matter.  I'm guessing under normal conditions the ECU is able to self adjust and keep everything smooth.   Right now my best performance is happening by lowering the base map just enough to where the ECU us doing short term cut of about 45% to reach the target Lambda of 14.7.  That way when I start putting load on it still has high enough fuel map to not be so lean.  After 2500 rpm I raised the base map to what would be really rich at no load, but still helps with the lean spots on load.  I figure I don't have much reason to be above 2500rpm with no load.  When watching other videos it seems their target is reached much faster than mine.  Mine takes forever to adjust and reach the target. My next few days will be spent making sure timing is good, it was running fine before doing the ECU and DBW swap, but want to verify.  I'll also probably swap in the new injectors I bought as well as a walbro 255 pump.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
