hey guys
pulling the volk te37s off my gtr prior to sale.
they are bronze and 17x9.5 with +12 offset and i have recently fitter new rubber (235/45)
post-15480-1255946942_thumb.jpgpost-15480-1255947064_thumb.jpgpost-18271-1125028296.jpg
not really loking for a cash sale, looking for swaps with a full set of wide 17''-18" deep dish rims (going on s14a)
if anyone has something on offer please let me know.
im located at goldcoast qld
only have old pics atm (wheels are very dirty). will get some new ones asap
to keep mods happy i will put $3500 on them.
regards- alex
0416702037
Edited by alex.a
https://www.sau.com.au/forums/topic/292628-fs-volk-te37-bronze-17x95-12/
bump
d_spec- msgd you about your wheels. very keen on them. when i asked about transport all you replied is "i dont like taking risks".
all i can think is fax a copy of each others drivers licences etc before wheels shipped??
just a thought - why dont both of you exchange good at a common location,
i.e. alex you post the wheels to someone you know who lives where d_spec lives
d_spec you go there, and give alex's mate the cash, and take the wheels
and alex you get the money off your mate :)
    • Maybe it's time for a M3 F80 LCI, and leave it stock.  Drive it to a shop, sip on your latte with nutmeg whilst it gets serviced and on the way home swing by and grab some chai mix for the evening.
    • Great work! Thanks for documenting the process.
    • How would you even adjust the clutch if the pedal already has the correct free play? The operating cylinder has no adjustment in mounting position or rod length. On pull style clutches there is also no ability to adjust the bearing carrier. Push type I can see how adjusting the carrier height makes it all work.   If this is the twin plate clutch did you verify that your friction disks were oriented correctly? It's not mentioned in the directions at all you just have to notice that one side the friction disks have a part number on the hub fingers and a subtle coning to those fingers. Another thing that I noticed was if you put the friction disks in backwards the pressure plate fingers will not be even and flat when the clutch is installed.
    • yeah, mechanically, it is probably do-able, off the top of my head, there would be the transfer case, which I believe will bolt up to the rear of the RWD transmission, the shorter rear tail shaft. A front drive shaft, front diff, engine upper sump, front drive shafts, front hubs and front AWD struts (they are shaped around the front drive shafts), LCAs (at the very least from the front suspension) oil cooler.  You might want the rear diff from an AWD too, so you can be certain the front and rear diff rations are identical.  Who knows what brackets and mounts you might need.  So a whole doner car might be the best option if you need to maintain RHD. Then actually making it work, that would be a whole different story.
