Raws car
1992 R32 Gts-t
Auction grade 3.5 car
100,000 on the 25 package
motor was rebuilt with new rings and bearings before fitting 20,000km ago
VG30 op6 Turbo (larger rear housing same as r34 gt-t)
New Arp headstuds
New timing belt
pod filter
Tomei 256 Intake cam
New Tomei 1.2mm metal headgasket
New front mount intercooler
full exhaust turbo to tip
full type M body kit rear pods etc
New extreme heavy duty clutch
New D1 strengthend shifter (same through just more postive feel)
Non Hicas S13 rear craddle
Alloy craddle bushes
coilovers
New Section rear camber arms
Ikea Formula Traction rods
New Kts tie rod ends
New Ikea Formula tie rods extra lock!
New Kenwood head deck
New Alloy Steering bush
New Nolthane Steering rack bushes
HID Cats Eye headlights
Gtr fuel pump
new clutch master cylinder
New front Brake pads
all new fuilds engine oil, brake fuild, clutch fuild, gearbox oil, diff oil all changed 2,500km ago or less
Alarm , keyless entry
custom tailshaft
custom gearbox mount
rb25gearbox
Pioneer 6inch speakers front and rear
Pioneer amp
Front slotted rotors
solid engine mounts
Jjr engine daMPNER
Front strut brace
Battery mounted in rear
New battery
Greddy stytle plenium
Nisno fuel pressure reg
Turbo smart fuel pressure gauge
Autronic smc computer
$9,500 firm SA Strathalbyn 0431 540 141
Edited by driftn32
https://www.sau.com.au/forums/topic/292676-r32-with-rb25-sa-9500-firm/
  • 3 weeks later...
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
