Hey
Ive seen on the internet that the engine power ratings on the R34s with the Neo Straight six's are quiet impressive...
Ive seen 2L neos advertised but havnt read about them...
The 2.5L Non Turbo producing 200kW
2.5L Turbo producing 206kW (same as 2.6L Twin Turbo but less torque).
Ive read this on the internet a few times..
Just making sure its correct? And also what does the 2L engine produce seeing as some R34s have them (so ppl advertise)??
https://www.sau.com.au/forums/topic/29277-skyline-r34/
I read it in errr... a site lol
How come the neo engines are so much more powerful??
Not that im complaining! :)
Read the N/A was 200kW but a fair bit less in torque...
206kW is the legal limit in Japan for stock engines im guessin right..?
Because all major engines STOCK from diff makes etc 206kW.
I cant wait to get an R34!!! Be waitin for a few years tho... :)
https://www.sau.com.au/forums/topic/29277-skyline-r34/#findComment-599882
The neos are also in the Nissan Laurel.
Well the rb25det Neo has different ignition timing ( more advanced VVT system). I guess thats how it got some of its extra power.
All the Neo Motors use whats called a Lean-burn System. Hence ( low fuel consumption )
I found out that there is a 2L neo. It delivers maximum power of 155HP. which really isnt much. I suppose its pretty good for an NA 2L
It would have cost nissan alot more money getting 200kw out of a 2 litre.
Now you said that the 2.5L Neo "NON" turbo makes 200KW
Then you said the 2.5L Neo "TURBO" makes 206KW. What is the point of the turbocharged motor if they both make the same power??
Nissan could have kept the 2.5L an NA motor and still get GTR power.
Well really the 2.5 NA does not make 200KW, Its 200HP
the Neo RB25DET model makes 206KW (280HP)/6,400 RPM
34.0KG/3,200 RPM
CR = 9:0:1
https://www.sau.com.au/forums/topic/29277-skyline-r34/#findComment-599922
The R34 25GT (NEO RB25DE) makes 200PS standard (around 200bhp), not sure KW's. which is slightly more than the RB25DE found in the earlier R32/R33. The engine also has higher torque outputs, and late model R34's have a slight improvement over earlier R34's. AFAIK, R34's were available with either Triptronic Auto boxes (+ / - gear change and steering wheel controls) or a 5sp manual.
On paper the R34 GTT (RB25DET) and the R34 GTR (RB26DETT) put out the same power (280ps), but of course, that's "on paper"...
https://www.sau.com.au/forums/topic/29277-skyline-r34/#findComment-599980
>jazza08: Looks like your confusing yourself there dude! :)
Just relax, one question at a time, and "All will be rrrrrrrrrrrrrevealed"... (Thumbwars)
Thanks Dave for that "Gem" :) about the Neo-6 power outputs... seriously, how many mouse clicks did it take to get some official figures? 4? 5?
https://www.sau.com.au/forums/topic/29277-skyline-r34/#findComment-599985
Rezz - about 3 or 4!! :):):(
As an aside, most of the people I know of, who drive an R34 with the triptronic box say that don't usually bother with the steering controls...
I personally think Nissan did a very good job in upping the power figures for the R34 range, by tweaking the RB series engines, improving (or adding?) VVT to the NEO engines they managed to boost power/torque by a fair bit...
So that always raises the question - how come the R34 GTR doesn't get VVT and NEO technology?
Dave
https://www.sau.com.au/forums/topic/29277-skyline-r34/#findComment-600056
i'm no expert, but i think that the GTRs actually have a stock output close to 300kw, probably a little less. The only reason that they say it has 206kw is to comply (ON PAPER) with the regulations. And i think that there are no more restrictions in japan for power output, need i say more about the next GTRs power??? again im no expert, so someone correct me if i'm wrong.
https://www.sau.com.au/forums/topic/29277-skyline-r34/#findComment-600250
If u even take the GT-T power output as correct, 206kw's, a stock dyno run (148rwkw) shows pretty much 30% power loss thru the drive train, that's 30% not 33%. If u translate this powerloss percentage to GTR's at about 190 - 195rwkw's, making them about 280kw's at the fly.
Now i'm not sure if transferring 70% of the engine power to the wheels is reasonable to assume, but if it is 206kw for the GT-T and 280kw for the GTR sound about right.
Oh and just in case u didn't realise, the GTR engine is 2.6 litres and has 2 turbos, instead of one :cheers: RB26DETT
Tiptronic can be done via the gear stick as well yeah? Or is just steering wheel mounted buttons?
And the "206kw" limit was a "gentlemans agreement" in Japan between the different car manufacturers. But if u look at some of the cars that have been produced, 22B STi's, GTR's, Twin Turbo Supras, etc, they haven't been following it completely. But the agreement is no longer so yeah, time for the Japanese cars to mix it with the Euro boys in terms of power output.
cheers.
https://www.sau.com.au/forums/topic/29277-skyline-r34/#findComment-601371
You can change gears with a tiptronic on the steering wheel or with the gear stick. I have also heard that most people don't use the buttons on the wheel but I do all the time. I think it's because from the very first day I owned it I used them.
The only problem I have is that if you're booting it you have to press the button about 1000rpm before you want it to actually change gears because the revs climb so quickly.
https://www.sau.com.au/forums/topic/29277-skyline-r34/#findComment-601595
NEO stands for New Environmental Optimisation or sumfin like that, all it duz is make the emissions from the engine better. The increase in power is from the upgraded ECU that accompanies the engine... don't believe the hype :)
https://www.sau.com.au/forums/topic/29277-skyline-r34/#findComment-601839
Spot on FunkyMonkey - the NEO part of the R34 engines basically means they've tweaked it to produce fewer/cleaner emmisions. However, the R34 engines do benefit from ECU tweaks (and also manifold flow characteristics I've heard) that give it the extra power. Not forgetting improvements in the VVT side of things...
BTW, NEO = Nissan Ecology Orientated performance... :)
https://www.sau.com.au/forums/topic/29277-skyline-r34/#findComment-601987
The gentleman's agreement is just that, an agreement - it's not legally binding. There is a hell of a lot more mutual agreement between companies in japan, as opposed to western nations. That's one of the reasons why you often find that pricing for similar products can be very similar between different companies (ie: intercoolers, etc).
The reason for the kW (or we should say, ps) limit is (apparently) to keep the companies on a level playing field and/or to stop any potential power 'wars'
If you look at the cars that exceed the kW agreement - they tend to not be directly from the big companies (HSV is to holden as Nismo is to nissan).
IIRC, the car with the most power over the advertised 280ps is the toyota supra (though the s8-9 FD rx7 probably has even more if you consider power:weight)
https://www.sau.com.au/forums/topic/29277-skyline-r34/#findComment-602108
    • Did this end up working? Did you take some pictures?
    • And finally, the front lower mount. It was doubly weird. Firstly, the lower mount is held in with a bracket that has 3 bolts (it also acts as the steering lock stop), and then a nut on the shock lower mount itself. So, remove the 3x 14mm head bolts , then the 17mm nut that holds the shock in. From there, you can't actually remove the shock from the lower mount bolt (took me a while to work that out....) Sadly I don't have a pic of the other side, but the swaybar mounts to the same bolt that holds the shock in. You need to push that swaybar mount/bolt back so the shock can be pulled out past the lower control arm.  In this pic you can see the bolt partly pushed back, but it had to go further than that to release the shock. Once the shock is out, putting the new one in is "reverse of disassembly". Put the top of the shock through at least one hole and put a nut on loosely to hold it in place. Put the lower end in place and push the swaybar mount / shock bolt back in place, then loosely attach the other 2 top nuts. Bolt the bracket back in place with the 14mm head bolts and finally put the nut onto the lower bolt. Done....you have new suspension on your v37!
    • And now to the front.  No pics of the 3 nuts holding the front struts on, they are easy to spot. Undo 2 and leave the closest one on loosely. Underneath we have to deal with the wiring again, but this time its worse because the plug is behind the guard liner. You'll have to decide how much of the guard liner to remove, I undid the lower liner's top, inside and lower clips, but didn't pull it full off the guard. Same issue undoing the plug as at the rear, you need to firmly push the release clip from below while equally firmly gripping the plug body and pulling it out of  the socket. I used my fancy electrical disconnect pliers to get in there There is also one clip for the wiring, unlike at the rear I could not get behind it so just had to lever it up and out.....not in great condition to re-use in future.
    • Onto the rear lower shock mount. It's worth starting with a decent degrease to remove 10+ years of road grime, and perhaps also spray a penetrating oil on the shock lower nut. Don't forget to include the shock wiring and plug in the clean.... Deal with the wiring first; you need to release 2 clips where the wiring goes into the bracket (use long nose pliers behind the bracket to compress the clip so you can reuse it), and the rubber mount slides out, then release the plug.  I found it very hard to unplug, from underneath you can compress the tab with a screwdriver or similar, and gently but firmly pull the plug out of the socket (regular pliers may help but don't put too much pressure on the plastic. The lower mount is straightforward, 17mm nut and you can pull the shock out. As I wasn't putting a standard shock back in, I gave the car side wiring socket a generous gob of dialectric grease to keep crap out in the future. Putting the new shock in is straightforward, feed it into at least 1 of the bolt holes at the top and reach around to put a nut on it to hold it up. Then put on the other 2 top nuts loosely and put the shock onto the lower mounting bolt (you may need to lift the hub a little if the new shock is shorter). Tighten the lower nut and 3 upper nuts and you are done. In my case the BC Racing shocks came assembled for the fronts, but the rears needed to re-use the factory strut tops. For that you need spring compressors to take the pressure off the top nut (they are compressed enough when the spring can move between the top and bottom spring seats. Then a 17mm ring spanner to undo the nut while using an 8mm open spanner to stop the shaft turning (or, if you are really lucky you might get it off with a rattle gun).
    • You will now be able to lift the parcel shelf trim enough to get to the shock cover bolts; if you need to full remove the parcel shelf trim for some reason you also remove the escutcheons around the rear seat release and you will have to unplug the high stop light wiring from the boot. Next up is removal of the bracket; 6 nuts and a bolt Good news, you've finally got to the strut top! Remove the dust cover and the 3 shock mount nuts (perhaps leave 1 on lightly for now....) Same on the other side, but easier now you've done it all before
