Well I will try this again. Hello guys I am from the states and I am trying to put a rb25det in a 2+2 Z32 1991. Well before I get started and someone ask. Yes I have done the vgtt swap, three times, and all three times the engine were basically screwed. The first had lifter tick and locked up on a cold day. The second was done completely wrong by the mechanic and I scrap it. The third ran great until the white smoke started pouring out the drivers side, needed new rings. So after long debate and no success I said screw it and sold all my VG stuff and started over.
Well since researching all I can you guys seem to be the RB kings. So I decided to join to soak in all your your knowledge. There are very few here who have put a RB in a 300zx and they are not much help at all. So my goal is only about 400 hp and be daily driver thats it.
To start of my engine is out of a stagea which as we all know has a the same ecu as a R34. So I need some advice on that and just the basic on conversion. So here are my questions.
1. On the stagea harness there are some different connectors just above the ecu plugs. On a 300zx it has one of those plugs which contains the wiring for the consult, ignition, etc, but what is that other plug above next to that.
2. If I have a R34 style harness if I am using nistune do I use a version 4 board but the progam for a R33 rb25det. Its not a NEO so I guess I would have too use base RB25det.
3. How much Hp can I get with all stock running a greddy intake and 300zx maf
4. My oil tree does not have a oil tree on it or an oil cooler like some I have seen. Exactly where is the oil cooler on a stagea RB25det non-neo.
5. Finally if any one has some good pics showing the different parts of a stagea engine or pics of a Z32 with a rb swap it would be greatly appreciated. Wiring looks like the hardest thing now.
https://www.sau.com.au/forums/topic/292872-rb25det-in-a-91-300zx-22/
The z31 200ZX?? Comes out with an RB20det asuming the engine bay is the same size as the Z32 there should be no issues with fitting the engine
Sorry about typos up top I meant the oil sensor. On some of the RBs I have seen there is a oil pressure sensor on the oil tree next to the filter where is it on the stagea.
Also since I got a oil pan out of the 200zr fitment should be no issue but its the harness. I cannot figure exactly where all the connection go and I also want AC. Anything special to wiring up the AC. On a Z the ac has a small connector that hooks into the main harness. Im not sure if the ac hooks into the harnesee on a Rb. Also the Z has two harnesses, one for the engine and one for everything else.
Also does the stagea RB engine use map or maf and what is the difference.
Have you checked out the Stagea FAQ? http://www.skylinesaustralia.com/forums/St...nd-t102808.html
There are some pics in this thread of a zed with a rb25 in it.
http://www.aus300zx.com/forum/showthread.php?t=289044
Are you on rbz32? http://rbz32.com/
There is plenty of info on there regarding rb swaps into the Z32
If you need wiring digrams on anything be specific and i can look them up in FAST for you.
Hey I appreciate that I use too have that program. I love the charts and printouts. The main thing I am wondering is on the harness. Is the RB harness a one piece with cluster connectors and all or is it a two piece like the 300zx Z32. The Z32 have an engine harness for the engine, ac, mass air and consult port. Everything esle as far as the dash, fans, lights, fuel pump controller, steering assist, pwr brakes and all that are on the sub harness. I see a lot of connectors on this RB harness that makes me think it is a one piece harness.
Considering a z32 ECU can be used to run an RB25 engine.Why not keep the z32 ecu and loom and adapt it to fit the rb25? Should be fairly easy change a few sensors/plugs over and your done.
I already sold all from the Z. lol. I was going to use the Z ECU thinking I was going to get a r33 harness and loom. Instead I got a R34 style ecu and loom. So I cannot use the Z ecu now. So the engine is completely wired up all I have too do now is connect it to whatever is needed in the car itself.
don't let John @ UAS see this thread.. he will get angry
LMAO yeah i am already hearing it from all my Z club friends most do not talk to me any more. lol. My plan is to get this up and running then get a RB30 block and build it up. Using the heads off of this engine I will have the infamous RB30. Now with that being the case even a VG owner would have to bow down. With a 3.0 running a fat turbo and inline 6 I will kill almost any street legal supra or Z32. lol
I can get the block for like 450 shipped. So basically I want to get this up and running and by the spring I will start putting the RB30 in. That will be sweet.
Oh does anyone know if a stagea has VTC or not.
    • I thought I'd do a write up on an auto transmission fluid change for a the nissan 7 speed Automatic. At some stage the genius engineers decided that the fluid in the trans was "for the life of the transmission", (which seems kind of self supporting to me) and removed the dip stick and fill tube (funnily enough there is still a casting for it). Anyway, for this job you do need 2 specialist tools in addition to regular hand tools, jack and good chassis stands. You need a way to pump fluid up to the transmission; I got one of these but there are plenty of other options: https://www.ebay.com.au/itm/364584087070 Don't trust the generic listing though, it does not come with the required adapter for the Nissan 7 Speed. You need one of these, can't do the job without it: https://navarapart.com.au/product/genuine-nissan-patrol-y62-d23-np300-navara-re7-dipstick-fill-connector1 You need a heap of compatible transmission oil. Could be Nissan, could be anything else rated for Nissan Matic S. You need at least 10 litres, I had 15 to give it a better flush... Also, you need some biiig oil catch trays, at least one of these, or bigger if possible (volume was fine, size was very marginal): https://autobarn.com.au/ab/Autobarn-Category/Tools-%26-Garage/Specialty-Tools/Oil-Service/Garage-Tough-Oil-Drain-Pan-Black-16L---GT1068/p/TO03191 Finally, a measuring jug is very useful if your pump does not have volumes marked on it, I got a 6l one: https://www.repco.com.au/oils-fluids/fluid-accessories/measuring-jugs/penrite-measuring-jug-6l-pmj006/p/A5322648 Oh, and gloves.....this stuff is horrible (not as bad as diff oil, but getting there) ....First, jack up your car.....
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
    • What are we supposed to be seeing in the photo of the steering angle sensor? The outer housing doesn't turn, right? All the action is on the inside. The real test here is whether or not your car has had the steering put back together by a butcher. When the steering is centred (and we're not caring about the wheel too much here, we're talking about the front wheels, parallel, facing front) then you should have an absolutely even number of turns from centre to left lock and centre to right lock. If there is any difference at all then perhaps the thing has been put back together wrongly, either the steering wheel put on one spline (or more!) off, and the alignment bodged to straighteb the wheel, or the opposite where something silly was done underneath and the wheel put back on crooked to compensate. Nut there isn't actually much evidence that you have such a problem anyway. It is something you can easily measure and test for to find out though. My money is still on the HICAS CU not driving the PS solenoid with the proper PWM signal required to lighten the load at lower speed. If it were me, I would be putting either a multimeter or oscilloscope onto the solenoid terminals and taking it for a drive, looking for the voltage to change. The PWM signal is 0v, 12V, 0V, 12v with ...obviously...modulated pulse width. You should see that as an average voltage somewhere between 0V and 12V, and it should vary with speed. An handheld oscilloscope would be the better tool for this, because they are definitely good enough but there's no telling if any cheap shit multimeter that people have lying around are good enough. You can also directly interfere with the solenoid. If you wire up a little voltage divider with variable resistor on it, and hook the PS solenoid direct to 12V through that, you can manually adjust the voltage to the solenoid and you should be able to make it go ligheter and heavier. If you cannot, then the problem is either the solenoid itself dead, or your description of the steering being "tight" (which I have just been assuming you mean "heavy") could be that you have a mechanical problem in the steering and there is heaps of resistance to movement.
    • Little update  I have shimmed the solenoid on the rack today following Keep it Reets video on YouTube. However my steering is still tight. I have this showing on Nisscan, my steering angle sensor was the closest to 0 degrees (I could get it to 0 degrees by small little tweaks, but the angle was way off centre? I can't figure this out for the life of me. I get no faults through Nisscan.
