  • Replies 95
I'll sell u my 34 rims for $450 with tyres :thumbsup:
3 outa 4 centre caps tho and tyres are very legal and been through regency fine.
You talking about these rims that i borrowed? They look ok without the centre caps.
Huge thanx for the rims Luke, I can now stop boring my girlfriend with all the dif sizes and prices I keep seeing online and wishing I had :)
In true Awsam fashion though, and further proof even the simplest of things with cars for me are made difficult..
My jack handle snapped while putting the rims on, so my skyline is now stuck suspended until a mate cbf'd comming over with theirs lol
use your spare jack that should be in your boot.
ive done the same thing not to long ago with my sil.
Spare jack.. tick
jack handle... um.. where? lol
Doesn't matter now anyway, got a 4WD hydrolic lifter to put them on. Doesn't matter which R34 rim i put on the front, they scrape my calapers. Makes a disgusting clunking noise and messes with my steering real bad. The calaper has left a perfectly straight groove in the rim *sigh..
I'm about done with this skyline, all the simple things i've had done to it have turned into absolute nightmares, this car has me completely exhausted and I think the next thing that goes wrong I'm just gonna get rid of it and go back to driving my Calibra.
They hit the caliper? they cleared my brembo's and chad's stag. Thats odd.
Yeh was one rough ride man, I posted a thread about my problem. Maybe I have different calipers than I'm supposed to???
Maybe there's something wrong with my suspension, the front drivers side is a little spongey, and the tyer on the R34 rim seems to be touching the arm bit above the wheel very slightly every now and then.
thread has pics of the calipers, will post a pic of the groove left in the rim aswell
http://www.skylinesaustralia.com/forums/R3...-C-t296066.html
Edited by awsam
Hard to tell from the pic. I'll see if I've got a small spacer for you to fix it rubbing.
I've got a set of 5mm slip on spacers that luke removed off my car a few months ago that u can have for $20 if u like?
-D
-D
How's the vibration with a spacer on the front? I was going to take an angle grinder to the caliper and shave a couple of mil off LOL! f**kin take that!
This thread has the pic of the actual front caliper
My calibra has similar looking Calipers to the rear ones pictures in that thread, but on all 4. I thought maybe my 33 was supposed to have the same style rear ones all the way around also..
Edited by awsam
I didnt know the spacers were on all 4 wheels when I bought it, and tbh I didnt notice a difference when they were off, so I can say confidently that if you bolt your wheels up tight, it wont be an issue :happy:
-D
-D
Hrmn I think I'm prob just going to have to do that. Will i need to put all 4 on? Rears sit perfect as is. Are spacers illegal in SA?
yeah, both slip on and hub centric ones are illegal but paint them black and itll be harder to see.
also, depending how big of slip on spacer your get i would look into getting longer wheel studs but thats just me.
and if you use hub centric ones, get lock tight glue stuff that can be found at any car place like autobarn along with slip on spacers
hub spacers can be bought at wheelworx if your wanting them.
luke, remeber taking my 34 rims off my 33. they have some decent sized hub centric spacers on there to clear the brakes.
34 rims will also need spacers on a 32
are slip on spacers illegal? my car passed regency with em both times. never even got mentioned whilst in there.
To glue the spacer to the rim?
you use the lock tight on the bolts in the hubcentric spacers to make sure they dont come undone. they come with a different set of bolts. dont use hubcentric spacers with the 34 rims its not neccessary with the 34 rims as 5mm spacers will do the trick
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
