are slip on spacers illegal? my car passed regency with em both times. never even got mentioned whilst in there.
yes, they are illegal.
if they look for them or not at regency is up to them. or your running such small spacers that it makes its hard to see.
i didnt know i had slip on spacers on the back of my car till the wheel came off.
  • Replies 95
yeah thought they were illegal must have just got lucky. and yeah using spacers of any sort isnt the best idea if u wana keep ur wheels on ya car haha
yeah , only if you dont do them up tight enough hahaha
good memories xD
Should i be concerned with a 5mm spacer? This sort of has to be a long term solution lol
I've also read that i'll need a Torque wrench to sort the nuts out before i drop the jack??
Also been reading that slip on spacers are a waste of time?? Hubcentric ftw??
Edited by awsam
5mm spacers shouldnt cause you any trouble. and if i recall, the smallest bolt on hub centric spacer you can get is 15mm, which might be a bit much for your application.
but theyre not a long term solution, a set of wheels that fit is a long term solution.
i had similiar troubles, set of wheels fouled on the spring seat when i went coilovers, ran 5mm spacers for about a month, then bought wheels that fit... well, they clear the brakes and suspension at least.
as for the torque wrench, its best to torque up your wheel nuts when you put a wheel back on.
If you wanna keep the stock look, get a set of 33 gtr wheels, cheap, look good and im fairly sure they will fit no worries.
Yeh unfortunately changing wheels (other than back to R33 stock 16"s) will not be a financial option for some many many months.
Just driving with the stock 16's on the front and the r34 17's on the back LOL! It looks a little weird but feels better as my old 16's were bald
as my head :P
Edited by awsam
as my head :P
put it the other way around. the 16's on the back and 17's on the front. looks like a thrash car then haha
Thanx for the spacers D.. whacked em on the front, placed them and tightend the nuts real precision like.. I was a master lol. No vibration at all and barely @ 120kmph. Steering, braking.. everything feels as it should. I'm not getting to excited just yet, knowing my luck a wheel will fly off while @ 90kmph, but right now everything is sweet.
Thanx again D and everyone for the advice.
    • @666DAN sorry to bring you and old thread.     I've got my de+t done and it's all running great other than 1 small issue.    Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd when selected . But nothing when in  drive or what gear your in when you pop it into tiptronic. I'm sure there is maybe 1 wire in the ecu plug I need to move to rectify this. Do ya have any ideas?     Cheers man
    • Well I recently changed my rear axles and was thinking if I bumped anything, I have been driving the car for a while now though... But it has been raining today so everything is wet under the wheel arches. Brakes feel fine and can't hear any of the metal screamers, I had a squeak coming from one of the handbrake drums but that seems to have gone away a while ago. I was going down a hill when it lit up and I did feel the abs bite for a second and question why it did it?
    • Correct. Um. I dunno. I haven't cared enough about the way that the NA cars work to know for sure. But..... The 33/34 turbo manual cars have an electronic speed sensor in the gearbox that outputs a +/- (ie, sawtooth AC) voltage signal. That is connected to the speedo. The speedo then outputs a 0-5v square wave (ie, PWM) signal that the ECU (and any other CU on the bus) sees. The speed sensor is NOT directly connected to the ECU. So here's the problem. Your new ECU expects to see the PWM signal, but must somehow be getting a direct signal from the diff speed sensor. Which would suggest that the wiring of the NA car is not the same as the turbo cars. I think you will need to spend some time with (hopefully the wiring diagram for the car) and a multimeter to see what is connected to what. Then, presuming I am correct**, you would then want to separate the ECU speed signal input from the rest of the car's wiring, and probably either buy a speed signal converter, or build one using an arduino (or similar). That would take in the speed sensor signal and output a scaled (and suitably rearranged) signal for the ECU. ** We shouldn't presume that I am correct here, because there might be something else crazy going on. I don't think you could convert the speedo to be fed from the gearbox sensor, because the pulse rate from that sensor is probably different to the diff sensor and then the speedo would read wrongly. And this also wouldn't fix the ECU's problem either, because the ECU doesn't want to see the gearbox signal direct either (assuming that they are all on the same wiring, for some odd NA related reason, see above caveat!) Does this help? Probably not. Can you make it work? Almost certainly. With the above work. You should buy a handheld oscilloscope from Aliexpress so that you can view these signals directly. Connect up the probes and drive the car. Show photos of the screen when drving at known speeds and connected to different places, and we'll see what we can learn about it.
    • Assuming your brake pads are not worn right down, I'd add a little brake fluid. Is there any sign of a brake fluid leak?
    • Hello all,  I need of some help. On my drive home my handbrake light lit up and started flashing. When I got home I checked my handbrake sensor under the centre console and nothing seemed out of the ordinary. I have scanned my car via the consult port, no codes shown. Checked my brake fluid as well which is half full. Tried unplugging the brake master but it didn't change anything. Thoughts on what it could be? The master float doesn't seem to be stuck. My car is an 1998 ER34 sedan GT. No hicas but has ABS Photos below 👇🏾
