ok guys, after going through my garage i found (after 3yrs) nearly new headlights for r33 skyline, series 1.
they are in excellente condition with no scratches at all... LIKE NEW
not sure about price, so if u make any genuine offer i will consider it.
or help me and advise me how much i should ask for them
PS. have seen used silvia headlights going for around $250 each
https://www.sau.com.au/forums/topic/29385-fs-skyline-r33-headlights-cheap/
  • Replies 54
Consider:
Have bought 100% brand new indicator assy. from Nissan dealership (usually higher priced) for $140 the pair.
You may have seen some fool asking $250ea for silvia headlights, but were they sold at that price?
Remember, your lights are second hand, they may be in great condition but they are still second hand.
So if you think i am not GENUINE post a price, as stated in the rules.
Alan
Series 1 Headlights usually go for $500-600/pair, and are quite rare to be seen up for sale. There is a big market for them from all the guys who smash the fronts of their cars.
You CANNOT buy these headlights for $140/pair from Nissan :cheers:
They're more like $800/pair for the series 1 headlights and $1500/pair for the series 2 headlights.
How do I know? Because I have bought Series 1 headlights new from Nissan before at trade price and quoted out the Series 2 ones, but balked at the ridiculous price.
al
1. it was not some fool asking $250 each, but couple of spare parts shops in sydney... no names
2. yes i think ur offer is not genuine at all
3. these headlights are pretty rare anyway as far as i know
4. series 1 are about $800 new, series 2 $1500 new
thanks 4 ur offer anyway
i bought a very close to new passengers side r33 s2 headlight for 250 the other week
was wondering if u wanted to let one go for 250 (passenger side one of course)
for a mate
Guest darrinspencer
al
You can buy BRAND new lights series 1 from Nissan Australia for $385 each
series 2 are about $400 each
if yours are as good as new but second hand i will offer $475 for the pair delivered to Brisbane.
any chance of some photo's
[email protected]
THey are the 4 door and fit into the 2 doors with no problems.. i have them on my car in Australia.. gives a more classy look.
wld33R .. honestly mate.. those are in v.good nick, give a call to some second hand shops and see what the price they sell. I got mine with the car, but i have asked one shop to get a quote.. i was quoted at 650 for a pair... so not sure.. mm.. maybe i got quoted a big high? *shrugs
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
