5quarts
I'd be putting in another quart due to the fact it's a GTR. They are well known to have oil issues so the extra 1/2 quart only helps. Plus I have found 5L to be just sufficient for a GTR, 5 quarts is only 4.7L. Does 5 quarts get you on the full line or just below? (inc filter of course. And run engine for 30 seconds)
I am currently having a slow oil leak on my Trust oil cooler, mistake I made was to slacken the lines to drain the old oil from it. Have reinstalled them and now getting a leak. Is there an O-ring or something that may need replacing as it looks to be coming from the back of the fastener and not the front going to the sandwich plate.
  • 1 month later...
Little update here guys...
Normally i overfill it to almost the hump on the dip stick and after monitoring it for a while noticed that it only 'disappears' until it reaches exactly on the H line and doesn't seem to go any lower from there.
So i guess it was just the 'overfill' being burnt off.
The bad news though is it suffers from surge when it is on the H mark and guess what.... its in a rwd chassis!!! Gtr sumps are truly shit!!! I can't believe Nissan even released the Gtr from factory with this problem !
Anyway i'll keep monitoring it while trying not to pull too much G's and see how it goes but i should be good to go :banana:
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
