Vehicle only requires washer jets to work & Catch can to be plumbed into intake for Road Worthy
For Sale is my highly modified 1995 R33 gts-t series 1.5 rb25/30 hybrid. It is currently making 450rwhp on a low boost setting of 18psi tuned by 101 motorcafe. The setup was always to be very responsive, very driveable and very reliable. The new engine has done about 15,000kms and is blue-plated along with the other modifications. It is built to handle alot more power than it's currently making and the tune is set to keep the engine far from its full potential. The car is serviced every 4,000ks using a K&n oil fiter & Castrol Edge 10w-60. Brake fluid, Coolant, Fuel Filter, spark plugs & all oils were replaced when the new engine went in. Selling as is.
Pics can be found here
120,000kms
Engine
Rb25 head
Arp Head studs
External oil feed to VCT
Adjustable Exhuast Cam Gear
Tomei Stage One Cams
Tomei Valve springs
Port and Polish head with match porting to manifolds
External oil return from back of head to sump
Rb30 block
Balanced crankshaft with Jun Oil pump collar fitted
Cp pistons 20' oversized
Spool rods
Acl Race series main and big end bearings
Tomei oil feed restrictors fitted
N1 Oil Pump
Trust oil cooler with thermostat
Aftermarket alloy radiator
Gates Triple Strength timing belt
All new welsh plugs
New Water pump
New timing belt tensioners
New Drive belts
Ross Balancer
Excede 5 Puk Clutch
Pwr Steering pump pulley machined to align with balancer
Induction
GT3540 Turbo with .82a/r exhaust housing
Tial 50mm external wastegate plumbed into the bottom of the dump pipe
GFP Plumb Back BOV
6 Boost exhaust manifold
Aftermarket intake plenum chamber with individual trumpets inside
103mm Throttle Body
Monkey Warehouse FMIC
3" titanium exhaust from the cat back
Turbosmart T-piece boost controller
Custom catch can
K&N pod filter
Fuel & Ignition
Walbro 500hp 255l/hr lift pump
Bosch 044 700hp External fuel pump
External undercar surge tank
Sard 850cc Injectors
N1 Adjustable fuel pressure regulator
Splitfire coilpacks
Double platinum plugs
Haltech E11v2 ECU
Apexi turbo timer
Wheels & Suspension
18" Alloys
245/35R18 Toyo Proxy 4's
King Springs
KYB struts
Hicas lockbar
Urethene bushs for rear cradle
Urethene rear swaybar bushs
Interior
Clarion 7" touch screen head unit
Kicker 4 Channel amp
Eclipse 12" Subwoofer
Eclipse 6.5" Splits
Boost guage & oil temp guage on A pillar
Centre dash trim & Door trims painted Silver
Blue Neons in driver and passenger foot wells
Trust gear knob
Exterior
Gtr front bar & customised grill
Licence plate, parker & low beam bulbs replaced with whiter lights
Clear Side Indicators
Freshly tinted windows
I have 4 wheel spacers that have never been fitted to the vehicle & 4 stocko rims
$14000
Located Mount Cotton Queensland. Ring Daniel on 0423437812
https://www.sau.com.au/forums/topic/294101-95-r33-gts-t-series-15/
    • There's restrictor pills in the stock boost control hoses. That's how they set the amount that was bled off and hence the "high" boost setting. The usual mod in the day was to remove it and send the "high" boost setting up to about 14 psi.
    • Thanks Duncan, that's the best info I've read. Furthermore after learning about the PCM programming side controlling the factory boost solenoid, the purpose of the solenoid is to "bleed" boost when pin 25 is earthed, thus allowing spring pressure in the wastegate actuator to overcome diaphragm boost pressure, thus closing or reducing the position of the wastegate flap creating more boost as the turbo is able to spin faster. It's pretty cool to see a designated Pill to do exactly this, would have liked to have seen it with a tiny filter over the end for those moments in vacuum.  The constant bleed pill has now been removed completely from the system and solenoid boost control has been restored once again.   Case closed 😂
    • The wideband reading is meaningless if it's not running. Why are you using shitty old sidefeeds on any engine, let alone a Neo? What manifold and fuel rail are you using to achieve that? Beyond that, can't help you with AEM stuff as I've never been their ECU/CAS combo.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
