Ok guys ... several items have been sold from my other post so im making a new fresh post of whats remaining and prices for each item or you can buy the lot at a combo special price :D
[referring to OEM factory stock r34 vspec 2 parts - all in perfect working order no issues guaranteed]
- shocks and springs $150
- cam gears $50
- pulleys $50
- camshafts $150
- front and rear camber arms $150
- fuel pump $150
- tail lights $250
- electric side mirrors $250
- oem single din pocket $50
Random
- brand new trust air filter $100
- brand new hks ssqv purple fin $30
- project mu brake pads HC+ front and rear with about 80-90% pad left $200
Total price is $1580
If you want the lot, ill do it for just $600!!! :(
Shocks
Filter
Tail lights
Cam gears
Pulleys
Camshafts
Project Mu HC+, hks purple fin, oem vspec 2 fuel pump with hoses [other items are sold]
  • 3 weeks later...
brake pads gone
Remaining -
- cam gears $50
- pulleys $50
- camshafts $150
- fuel pump $150
- tail lights $250
Random
Total price is $1230
If you want the lot, ill do it for just $400!!!
  • 2 months later...
    • My guesstimate, with no real numbers to back it up, is it won't effect it greatly at all.its not a huge change in position, and I can't see the air flow changing from in turbulence that much based on distance, and what's in front of it. Johnny and Brad may have some more numbers to share from experience though.
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
