hey guys first things first , i'm having issues with my water pump i just got installed around 2 months ago .. As i work for autobarn i picked up a waterpump (TrueFlow) which is made in japan , so i thought for only 60 bucks what a good price .. I only just recently pulled of cam cover to find it looks like it has been leaking on the side where the pulley is . . I took it back to the mechanic and he told me the issue is that one of the bolts from the water pump doesn't match up to the block .. He thinks its an rb30 so im not gettin a good seal ? Is this ok to leave or should a fix it asap, obviously he isn't gonna help me out or anything .. Also on my power Fc my car is showing a water temp of around 85*c on normal driving but when a give it some loving it gets up to around 105-110*c and stays around that.. The gauge on dash seems to be in place it has always read ? Can anyone help me out with some info on my issues , cheers
https://www.sau.com.au/forums/topic/294467-coolant-issue-r33/
RB30, RB20, RB25 water pumps all the same.
Sounds like you're not getting a seal because he didn't blue-maxx the shit right whoever did the work, and hasn't tightened it enough.
drain the coolant, rip off the cover again, undo the belt and pulley, unbolt the water pump, clean off the old silicone shit, replace with new Loctite Blue-Maxx silicone around all of the stud and bolt holes and around the entire sealing surface. not too much, but enough to seal the entire thing. pop it back on, tighten it up until it's juuuuust tight. then nip it up. replace all your bits, tension your belt via alternator. open the bleed screw on top of your manifold, take it out but don't lose it. fill the radiator with coolant (red if you're running red, green if you're running green). leave the cap off and start the car. let it run, and keep on topping it. run it until the thermostat opens, and keep topping it up until you can't fit anymore into the radiator. then tighten the screw back on (easier when the car is off) and pop on your rad cap. fill up your overflow to half way and job's done.
truflow is a good brand, and better than powermax. but no substitute for an N1 GT-R water pump, genuine. GT-R Water Pumps are anti-cavitation water pumps, but still fit the entire RB range of engines.
normal temp should be between 76-82 and up to 90 when pushing personally i cut it off at 95 so 110 is wayyyyy too hot!!
the dash gauge is crap and unreliable.
plently of people use the rb30 pumps with success, maybe see if you can tighten up the bolts, ideally it should be removed and resealed.
or buy the pump that fits :D
RB30 pumps are definitely different to RB25 pumps. Very similar but the RB30 doesnt have the elongated hole for the small bolt. I got around this by drilling & tapping a thread in the block to line up with the RB30 water pump. If you pull it all apart & have access to a tap & die kit, I recommend it. Also, not sure of importance, but 1 water pump I got had bigger impellers & less of them so I swapped it for a different brand which matched 25 pump impeller exactly...
This is CORRECT .. They are all different engines so they cant all be the same .. There is a hole which he stated was on the pump but there was no hole on the block ! Should i use a genuine gaskit ? Or that loctite stuff .. ? I just checked today and i'm not gettin pressure in my hose .. I changed thermostat and all the hoses , genuine nismo radiator cap and coolant and still isn't getting pressue in line .. I think the pump has failed as today i saw my temp rise to 145*c which i didn't see straight away so i think i've just f**ked my motor !
WP898 correct?
I too work at a parts store and have seen these go out for rb20/rb25 only to have them returned because of the one bolt hole not lining up.
I'd suggest genuine if another aftermarket one cant be sourced.
That's it kane. TF898 would be truflow p/n, but industry number still the same.
we don't get much call for RB25 water pumps out in the sticks but my listings all say 898 is correct and 890 is rb26dett.
better brands do make a difference. difference between nu-line pulleys and gates pulleys. same number - different size sometimes. aftermarket will never be 100% exact, but if it doesn't fit, it doesn't fit.
glenn, if it doesn't turn over, then yeah.. sorry.. you've f**ked it.
Stop spending money when you don't know what the issue is. go through your entire system and rule out EVERYTHING, if not get a mechanic to look at it. and stop driving it!
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
