Hey all,
Thought I'd share my experience,
Went to see Damien @ Final Inspection on Sat, All I have to say is he knows his stuff and does an amazing job, very professional.
My car as you may or may not know my car has just been resprayed and this was the first cut polish it has received, as per instructions not to get it done too soon. Also didn't want it getting botched by some hack :D
For anyone looking to get this done I can't recommend Damien enough, very reasonable price for the service provided, He was even kind enough to give it a wax with Carnauba Wax!
Here are some pics, I think it came out great. Let me know if you need details on price etc
Cheers,
https://www.sau.com.au/forums/topic/294471-final-inspection/
Hey buddy,
Sorry to hijack your thead but I must agree Damien is the best around, and if you are like me and like to do it yourself then he also sells the best products.
If you need the best supplies or best service and quality he is the only one to consider.
I was there when you dropped your car off, I would have said hi if I had known you were one of the SAU crew!
I bought myself some presents :(
And then went home and used some of them.....
hahahah, you most likely not only got possibly the best carnauba wax ever made (Royale) but you probably got a sealant layer underneath as well. Can't do all the correction work and not protect the car.
You can get decent carnauba waxes for around $40-$50 (p21s) but if you want to rush out and buy some Royale, you'll need about $18k handy :(
check with D, but you probably got FI Seal, followed by Royale - or possibly FI's own carnauba wax
Hey buddy,
I bought myself some presents :D
holy moly that looks awesome! Even my new coat of black paint isnt that shiney! not fair :)
So when you going to do my car? :(
Yeah it was the Royale, I almost fell off the couch when I found out how much that stuff was!
Lucky you!
Damian is probably the best Detailer in Australia.
I heard that a car from Dubai is being sent over for a Concours level detail. About AUD12.5K for that level of detail!
    • Hopefully it ends up being something manageable, like a hone, rather than a full bore—it would be a huge relief if it’s not as bad as it looks. Hang in there; these setbacks are annoying, but it sounds like you’re handling it as smartly as possible.
    • At the end of the day, it’s all about understanding the odds and being comfortable with the potential cost, whether it’s horsepower on a build or chips on a roulette table. And I have to say, the Laine example made me laugh—some people really do embrace that carefree, “roll and see” attitude!
    • Thanks MBS206, i got that PDF but got abit overhelm with all the connections and tracing of wires. I wasn't expecting to plug the dash harness anywhere. i was just going to use my electronics jumper wires to plug into the right pins like ECU power, ecu ground, ignition trigger etc... I do have a few ratchet straps locking it down tight. Fire extinguisher ready and only a small amount of fuel at a time, enough to submerge the pump.
    • Thanks GTSBoy, i will do abit more digging. I am missing a blue relay near the ECU connector... so i will chase that up in the next few days as well
    • https://yariksteel.ru/manual/R33/Skyline_R33_elektroprovodka.pdf   Page 18 should be what you want for the Dash Cluster wiring. Though, you don't need the dash plugged in to get the motor running. What you want is power as how GTSBoy said. You need to power the ECU. Find in the above link the ECU pin outs (Verify them before just connecting them up from things written on the internet). Find anything needing power, give it power, find anything needing ground, give it ground. Then give the starter motor power through a big cable, and bridge the solenoid on the starter straight to power too.  ECU will be on, and when you give the starter power, it'll spin the starter motor, and it should start. I also hope you have a proper stand, and not just the engine sitting on some wood. You will want it bolted down properly.
