1997 R33 Series 2 120,000kms
I have owned the car for a little over a year, before that it was owned by a friend for a about a year.
Serviced Every 5000km or less with Motul turbo light 10w 40w
Motul Diff Oil
Redline Gearbox Oil
Modifications,
Apexi Power FC Tuned at 12psi (made 201kw)
Blitz Dual SBC boost controller
Split Fire Coil Packs
Walboro Fuel pump
Blitz turbo timer
R34 Turbo (OP6)
RB20 Wastegate Actuator (10 psi)
Split Dump/front Pipe
3in Hi Flow cat (inside not bashed out)
3.5 inch HKS Hi Power Exhaust
Apexi Power intake filter on custom made Metal intake pipe onto the turbo
(Pod not totally boxed in but covered over see photos below)
Standard RRB20 Blow off valve
Greddy Front Mount Inter cooler and piping
Alloy Radiator
Heavy Duty Excedy Clutch
Braided Clutch Line
Braided Brake Lines (ADR approved)
Master cylinder stopper
Front and Rear Strut Braces
Bilstein Shocks and King Springs
Front Whiteline adjustable Castor Bushes (adjustable on car)
Rear Whiteline Camber Bushes
Work Emotions CR KAI 18 x 8.5 in all round
235/35/18 federal 595 SS on the front (70%)
235/35/18 Sumitomo HTR Z 3 on the rear (70%)
Work Wheel Nuts
M Spec side skirts and rear pods
33 GTR rear seat
Have had the Roof lining, A-Pillar and B/C Pillar trims redone in Black Suede (haven't done the sun visors yet)
Only need front GTR seats and interior done
White LEDs' in the cluster
Have Changed the AC Panel, cigarette lighter surround and ignition barrel surround lights all to blue LEDs'
Pioneer Head Deck (DEH-P6850MP)
Pioneer Front Speakers and tweeter
Pioneer Rear 6in Speakers
And finally the rear "Skyline" Boot garnish lights up red with taillights :(
There is probably more little bits and pieces i have forgotten but i think that will do, Basically the car has never missed a beat in the last 2 years runs great drives beautifully and handles well. Overall i think its one of the nicest R33's running around. Has been my pride and joy for a little over a year but its time for me to move on, Pictures Below feel free to ask any questions.
Price - $18,990 Will get RWC upon Sale
Plates Not Included
PM for my contact details if you are interested
and have a few more photos too
Cheers Scott
Edited by 13thracer
https://www.sau.com.au/forums/topic/294572-1997-r33-series-2/
  • 2 months later...
    • My apologies. I forgot we were talking about weird beard M series stuff. Had been talking elsewhere with someone about an R33 with similar subject and got confused.
    • Nope, I don't like the look of ND RF, or any ND really, I don't like their faces or arses, why, because of their "modern" lines, the NC, whilst "modernish" has a more rounded shape that I like Well, that's how my overly judgemental eyes see it anyway
    • Should be more than fine, especially the overall fuel pressure would never exceed 3.5bar (assuming that thing never gets more than 0.5bar of boost in stock form). According to the chart, it's 11amps.
    • I definitely know the first rule here, look first, ask second. I've seen many people get roasted 😂 I found a few diagrams for the RB, but I'm yet to come across one for the VQ. From what I have read, the pump gets the +12v along with the FPCM, and it's the negative wire that gets passed through the resistor to regulate the voltage. So I assume I can just ground the negative wire at the pump to eliminate the FPCM control. But I really wanted to see the VQ circuit diagram first to make sure I understood it correctly. Once the new pump is in I'll do some testing to see how it behaves, and in the meantime, I'll keep looking for a wiring diagram. Thanks for your help mate, your time is greatly appreciated.
    • Maybe? I have the Supercheap ToolPro low thingo. It has a somewhat smaller diameter lifting "bowl" than you would expect on a workshop grade trolley jack, and a split rubber pad to suit that diameter. It clears the "N1" style skirts I have. Probably wouldn't if the jack's bowl and a suitably larger rubber block were in use. Having said that though.....you only need the rubber block to exist on the inner side of the pinchweld, so could carve away any rubber that fouled the skirt, leaving some there for "insurance" </simples>
