Hi,
Have a 1999 Bayside Blue R34 GTR V-spec for sale. Absolutely immaculate inside and out, can not fault.
Is currently in final stage of completing 6 month long rebuild so will be available to see in 2 to 3 weeks approximately.
I am first Australian owner and have owned the car since Jan 2007 where it was completely stock. No accidents so far. Car has done total of approximately 77k km.
Heavily moddified with BRAND NEW Engine,
Mods list
Engine - All brand new parts
- 2.7l Stroker with billet crankshaft and rods
- HKS t51r Kai turbo
- Extended sump
- Nitto oil pump
- n1 water pump
- ARP bolts
- ACL race series bearing
- ATI harmonic balancer - 1000hp
- Full Port and polish of head
- Mines Triple Flow cam cover baffle plates
- Tomei procams
- Tomei valve springs and retainers
- Tomei Valve lifters
- Tomei gasket kit
- Supertech 1mm oversize valves
- Billet twin entry fuel rail
- Sard Big capacity Fuel Pump - plus 2 bosch 044 yet to be installed
- Adjustable Fuel pressure regulator
- Siemens injectors
- Nismo twin plate coppermix clutch (awesome clutch for everyone reading)
- Greddy intercooler
- Greddy hard piping kit
- Power FC - D-jetro
- Greddy boost controller
- Chrome coating of engine covers
- Engine catch can
Suspension:
-Greddy coilovers
-Greddy in car electronic damper adjustment
-ARC racing stabilizers (swaybars) - Front and Rear
-Cusco camber adjustable rear upper arms
-Cusco fron negative arms
-Endless brake pads
Interior:
-Alpine 7inch double din head unit
-DLS 6.5in splits
-DLS 3 Channel Amp
-DLS Magnesium Sub
Also:
-Kakimoto stainless steel exhaust
-Rays Volk GT-C face 2 19x10.5 rims
-Nismo z-tune body kit
-Nismo 320km/h speedo with 5k km on it ... Stock one will also be given
-Nismo L.E.D tail lights
These are the parts i can remember for now,
Will post proper pics when car has engine back in it with all new shiny parts. :P
As is imaginable i have spent thousands of dollars on the car and am placing the price at $85,000. If serious and want to throw me an offer just PM.
Edited by gtrr34owna
https://www.sau.com.au/forums/topic/294602-r34-gtr-v-spec-monster/
To be honest i dont know how the engine bay looks yet or how much power. Engine is still getting done due to mechanics timeframe of 1 weeks realistically being 1 to 2 month :) . As soon as its finished pics will be uploaded, hopefully that will be next week.
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
