I have a cefiro with a rb20e engine, the head gasket blew and when i pulled off the head it was in a bad state. I purchased a rb20e (carb) head and block, took off all my parts and put it on to the new head and block (converted it to fuel injected, so i used my distributor, air intake etc.) set the timing to tdc, at first it would not start so pulled of my injectors cleaned and reinstalled, it starts and idles at about 500rpm however when i put my foot on the X to rev it i get no response, it feels like its going to cut off and when i remove my foot it picks back up. any ideas?
https://www.sau.com.au/forums/topic/295339-rb20e-not-reving/
If it goes better when you back off from WOT then it means possibly that your AFR is out. Probably the timing as well.
You would have to assume that if you have replaced a faulty Head/Block with OK replacements,
and your bolt ons were running ok with your old Head/block prior to the faulty head problem,
then somehow your fitting of the items causes the engine to not start.
This could include the cam timing setup as well as the possibility of air leaks causing AFR problems.
1. RECHECK TIMING
2. CHECK for AIR/VACUUM LEAKS
3. CHECK FUEL DELIVERY & PRESSURE
4. CHECK SPARK
the block had rb20 as part of the engine number, the head looks like the ones that came on the rb20et. The block also looks different than mine in that it looks stronger, now in trinidad the a31 were sold new as the altima which came with rb24 single cam carb., this engine was bought from a foreign used dealer who imports used parts from japan, so i am not sure if thats how it came stock.
Probably 24 heads...and your problem, heads and block having timing trouble.
Check out what all the guys suggested, if it's still not fixed, engine swaps are f**kin easy on these things.
or even strip out the bay down to the block, and go DET heads and loom.
Sorry, I just reread the first post.
I thought you had bought a replacement head and put it on your existing block.
Just to clarify, You originally had an RB20E (fuel injected) and you bought a replacement motor which was carburettor.
Then you swapped all of your EFI stuff onto the replacement motor.
As far as I understand, RB24S and RB30S were the only carburettor RB engines. So I'm guessing that maybe you were sold an RB24S.
Although, you also said that the block has an RB20 engine number..... can you double check that?
After some searching I have found nothing relating to RB20S's. However the wiki article makes reference to a common mod being to put the a DE head on but retain the carbys for an RB24s. Perhaps you have an RB24s in disguise with an RB20DE head on top? or perhaps just an RB20e head? odd thing to get though :).
Quick edit: can't be a 20 head on a 24 because they are incompatible.
Daisu you are correct, my original engine was fuel injected, but it was hard to find a replacment one in good condition. this guy who i have bought engines in the past said he had a rb20 but with carb. and all i needed to do was use back my intake system along with the distributor. the engine was in good condition so i took it. on the block the engine number starts with RB20, i even took of the carb. myself, so it came like that from japan. now the tapit pan cover is shaped like the ones you find on the rb20ET. Based on what you guys are saying (that rb carbs mainly came on the rb24s and rb30s) so i am guessing that the person who had it in japan did a mix and match meaing put a 24 or 30 head on the rb20 block, If this was done to gain HP i don't know. I have tried to research the rb20 carb on the net but came up empty. The block is also different than my orig. one. it looks stronger, there are ribs on the side roughly where each piston chamber starts and finishes (like the rb30 block or even rb20ET) here are some pics
Edited by who's next
Man, please don't tell me you have a RB30 here in T'dad. I'll take it off of you!
You could have my engine for cheap and use back your old head. Only the lifters were beginning to make noise on my RB20E.
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
