hey guys i have a few parts i need to get rid of as they are taking up space in my garage!
all parts are of the R34 GTT Coupe..
Standard Bonnet - $150 (has slight damage on passenger side corner easily fixed and paint is fine) Painted in Dark Blue
Stock R34 Suspension - $200 no leaks perfect condition (fronts and rears)
Drivers side front Guard - $200 no damage at all Painted in Dark Blue
Stock Front Bar with Lip - $200 Few Stone Chips Painted in Dark Blue
TOP SECRET FRONT BAR - $350 Never Fitted BRAND NEW (paid $550 for it 2-3 months back never used)
Rear GTT Wing - $250 perfect condition Painted in Dark Blue
All Parts are in Hobart TASMANIA
can Post at Buyers Expense
all prices are SLIGHTLY Negotiable need this stuff gone
Thanks
https://www.sau.com.au/forums/topic/295787-r34-parts-sale/
How much would it cost to post to Newcastle?
hey mate depending on item you are wanting..
id say roughly $150 for the bars/bonnet etc.
and probably $100 for the smaller parts guard/wing etc.
this would only be my estimate if your interested in a part i can check for you but would also need your postcode.
cheers
https://www.sau.com.au/forums/topic/295787-r34-parts-sale/#findComment-4932209
hey mate, can you email me some more pics of the front bar and lip, including all damages/chips to [email protected]
cheers
yeah mate no problems, there is actually no damage to the bar at all apart from stone chips along the lip part.. when i got the car one of the mount points in the grill part has snapped off.. all mounts at either ends are good but there a 2 mounts in middle in grill one is good but one is snapped.
https://www.sau.com.au/forums/topic/295787-r34-parts-sale/#findComment-4934421
Love the color mate!!! i'd assume that you arent gonna separate the bar + lip...
thanks mate getting resprayed soon ;) ill post pics when its done..
trying to get rid of bar and lip together as im just after more room around my house and as i have a new bar just looking a getting some money together for the resprray :cool:
https://www.sau.com.au/forums/topic/295787-r34-parts-sale/#findComment-4938565
Thanks
LOOKS LIKE TOP SECRET BAR IS SOLD
all other items are still up for grabs :P
https://www.sau.com.au/forums/topic/295787-r34-parts-sale/#findComment-4939271
Thanks
PRICES DROP!! BUY NOW NEED THIS STUFF GONE!!
Standard Bonnet - $130 (has slight damage on passenger side corner easily fixed and paint is fine) Painted in Dark Blue
Stock R34 Suspension - $180 no leaks perfect condition (fronts and rears)
Drivers side front Guard - $150 no damage at all Painted in Dark Blue
Stock Front Bar with Lip - pending sale.. $200 Few Stone Chips Painted in Dark Blue
TOP SECRET FRONT BAR - SOLD
Rear GTT Wing - $200 perfect condition Painted in Dark Blue
BUY BUY BUY
https://www.sau.com.au/forums/topic/295787-r34-parts-sale/#findComment-4940540
both front bars are now sold
remaining items..
Stock Front Bar with Lip - SOLD
https://www.sau.com.au/forums/topic/295787-r34-parts-sale/#findComment-4940974
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
