Hey Guys, up for sale need the cash! so buy it
i bought this car from VIC and sent it over around 1 1/2 yrs ago!!
MODEL:
NISSAN SKYLINE GTT (RB25DET - Highflow Turbo)
SUNROOF!
5 speed manual....
COLOUR:
Peral White / black bonnet
ENGINE: 69,xxx KMS!!!! ( Real KMS )
Rb25det,
Pod Filter,
custom Stainless Steel Intake Pipe
Full JIC adjustables / Damper adjustable
Custom Full S/S 3 inch turbo back exhaust system.... (Decat) (got stock cat still)
Custom Detachable srceama pipe
New HighFlow rb25det turbo Done under 2,xxx kms (New)
GFb BOV adjustable
walbro 500hp in tank fuel pump
APEXI SAFC
X2 SPARCO BUCKET SEATS ( BLACK)
Car Tunned at 10 PSI at 6000RPM Ran 300HP at the rears, Easily More boost and better Sparks Can get Much Much Higher, was a Safe Tune.
Might of Misse abit
INTERIOR:
Custom All Re - Leathered Interior Dark Grey With red stiching, - Greddy Shiffter,
NOW WITH 2 SPARCO BUCKET SEATS.
EXTERIOR:
18" Linea Racing Rims Dark Gold / Black
Sunroof
GTR Bonnet N1
GTR Lights (xeon)
GTR WIDEN Front Vendors
GTR Defuser (Black) (off the car atm being repaired)
GTR NISMO Side's
C - WEST Back Bar
Clear Side Indcators
Thinking of chaning kit to uras!
Alot of Money and time spent on this car
All i can say is
YOU wont find a R34 4 door that looks like this around its 1 of a Kind, Drives well, Had no problems.
Dont drive it to much really lucky to bring it out twice a wee,
will Miss it as buying a house and having two cars and finding a new job its hard to afford but THE CAR IS looking for A GOOD HOME.
With Low KMS and a great looking car the next driver would be happy person!
Asking Price is 21,000 ONO
Car has been Rego'd in WA !!!
i still have all stock parts
MOB: 0401 264 192
NO TIME WASTERS PLEASE!!@
- Ricca
Photos below link..
http://www.skylinesaustralia.com/forums/R3...99-t282518.html
https://www.sau.com.au/forums/topic/295926-r34-4-dr-gtt-99-buy-me/
    • Hi. This is just my curiosity because iam sure the tuner figure something out...but either way i want to ask. The "problem" is that the Nistune ECU (Stagea FW and RB25DET NEO from Stagea) sees many times the speed than the speedo does(he says the speedo show 120 km/h - correct speed and the ECU shows like 510km/h ) I told him that this car/tranny getting speed from rear diff. If iam not mistaken the RB25DET NEO "need" to see tranny speed sensor? (my tranny has the plug for it). So couple of "question" If he connects/wire the speed sensor to the tranny...are the signals gonna intervene and if...what if he disconnects the rear diff one and the speedo stops working? Or the "new" sensor from the tranny "take over" and will not going need the one from diff? As i said i know he figure/get that done...iam just curious to know what are the solutions 🙂
    • Your IACV is set to idle too low. You need to adjust it via the screw Duncan mentioned. From memory it should be 650rpm with the valve electrics unplugged. What is it trying to idle at with the IACV plugged in?
    • Ahhh, I need the whole head unit. I definitely needed to roll back through and review your setup, ha ha! Neat setup they have going on. I just need a full double din head unit. But I want good and responsive. I might have to review what the likes of pioneer have out these days.
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
