Up for sale is a Nissan Skyline R34GT-T in Silver Color, Manual transmission, Factory Xenon HID headlight. Traction control & ABS
Imported since last year September with 70000kms and i am the first owner in Australia.
The car is in very good condition and well look after. Service every 5000kms with full synthetic engine oil.
Always fill with 98 Octane Petrol like BP ultimate or Shell V-power
Very long Registration until September 2010
Car has the following modification carry out from Japan:
Fujitsubo Turbo back exhaust including dump & front pipe
Ohlins Coilover suspension with height & damper adjustable
18" BBS rims, front: 18x8.5J +36 Rear: 18x9.5j +38
Short shifter
Apexi air Filter
The car has the following things replaced at last year Sept
Brand new heavy duty battery
Changed transmission oil with brand new Reline gear box oil
Changed Diff oil
Changed engine oil
Brand new EBC green stuff brake pad on the front
Brand new bendix brake pad on the rear
Brand new Greddy full auto turbo timer
Brand new 2way alarm system
Approximately 6 months ago, I replaced the coilpack with a set of Brand new Spiltfire Coilpack due to the original one was misfiring. (common problem on Nissan vehicle)
Recently replaced the tyre with a set of brand new Kumho KU36 $1000
Front: 235/40/18
Rear: 275/35/18
Have the window tinted 2 months ago.
Genuine Nissan Aero front bumper bar (plastic)
Genuine Nissan Aero side skirt (plastic)
Matching Rear pod (fiberglass)
Came with Factory Skyline carpet , Factory Skyline Manual & some Japan service history
A very reliable car in very good condition, come with RWC, genuine reason for sell, Price Negotiable
$19999 with RWC, contact Benny on 0433887191 or email [email protected], I may not able to pick up your call during work, drop me a sms if you cant reach me.
Car is in VIC, SE melbourne
Edited by benny_melb
  • 3 weeks later...
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
