Im selling my pride and joy.
Specs. Probs missed out of afew things here and there, its all hardwork, runs very well, Sounds great, Can do a 1.14 at wakefield >_>
Oh did i mention the cage is engineered, and P plate friendly!
Engine:
Rb25de : 209XXX KM, Always serviced under 5,000 km.
Made 113rwkws, gets 460km on 98oct.
Custom intake pipe
Oil filter relocated to behind front bar (easy to get to)
19 row Just jap Oil cooler kit
Carbine catch can
Iridium tipped spark plugs.
R33 Coilpacks.
New battery.
Double core 52mm Aluminum radiator,
Justjap water temp adaption fitting.
New blue Radiator hoses.
Stainless 2".25 Japanese Extractors
Xforce 3" Hiflow Cat
HiPower 3" Muffler
*No A/C pump, lines or condenser*
*No hicas bar, lines, pumps*
Justjap Hicas Lock Bar, P/S pump has had the rear blades removed and hose joints blocked properly.
Suspenion/handling:
Bilstein Shocks,
Pedders 6/8KG Springs,
D-Project top front camber arms,
Justjap Castor Rods,
5 Stud conversion,
Turbo caliper/rotor conversion front and rear,
Front Drilled slotted kangaroo pattern Rotors,
Ferodo Formula pads fitted with new rotors 3 months ago.
R200 turbo LSD, it does twins.
Front and Rear Strut Braces.
Rear Camber Arms.
New rear toe arms
Alloy soild Rear Subframe Bushes.
Interior:
Velo fixed bucket seat,
Bride s13/r32 Rail,
Stripped interior/Sound deadning, No rear seats.
Andra 4 point Half cage, padded and Engineered.
*Also i have the paper work(blue slip) to registered as a 2 Seater!
I do have all interior to return back to stock!*
3x Autometer Gauges Oil pres. oil temp, Water temp, sitting in a custom pod.
Pioneer head, Fusion 6x4 in doors.
Nardi Wheel
Drift Quick release + boss.
Drift carbon gearknob
Quick shifter kit
Glovebox handle broke, so there is a stainless latch to hold her up >_>
RPM 4 point harness.
Small fire extinguisher.
Exterior:
GTR Carbon bonnet,
GTR copy FB front bar,
GTR Grill,
GTR side skirts,
GTR rear pods
GTR Rear Wing
GTR Headlights
Rear cams toe hook
All guards rolled properly.
Bolt on 25mm front spacer.
10mm hubcentric Spacer rear.
Wheels:
4x Rays cerumo 17x8" front 9"rear +37 os. Powdercoated Bronze. 2 have slight gutter nonsense. Comes with brand new 255/40 falken, and 60% 235/45 falker.
4x Track rims, 17x8" 36+ os. Silver, comes with x4 shitter 215x45, 2x 225 kuhmo v700 semis (bald) 2x 215x40 re55 70% semis.
Oh also no time wasters.
Will be advertised else where.
13k ONO. No swaps. Please make me an offer. Rego till sept 2010
And i dont care for "Its NA, turbs sell for less... bull crap stuff"
Located Sydney Northern Beaches, contact me on 0424505711
Edited by VashR31
hey man very very nice indeed..!!!!!
very interested would you take anything off?
e.g. wheels.. gauges anything you want?
im on p's by the way and this is a nice little number. very rare to find..
cheers mate
very interested
Edited by Far_cry46
Because, this skyline you will find is quiet a rare find, there are plenty of r32s, that have had rb25de's swapped in, Where as this 25 came from factory.
No Vct.
Putting a turbo motor into the car would force its rareness and unique value.
But thanks for the kind words.
http://www.natsoft.com.au/cgi-bin/results....05/2009.WAKE.S4
There ya go buddy, position 27
And 3rd lap in video
http://www.vimeo.com/4807974
Oh also a dyno print. 151 rwhp.
What makes your boat of a looking model worth 13k then?
Edited by VashR31
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
