  • Replies 52
Nissan is a good start
Either way unless you're changing the belts yourself, sometimes its better to just let your mechanic buy the belts for you (assuming he is an honest bloke!). They get trade discounts, and if they buy the wrong ones it is their own problem.
I am due for some myself..same prob with the cracks...the Burson sales person told me to take mine off, then take it to the Burson store and he'll find me the 'right' replacement ones...when i get them done, i'll post up an aftermarket part brand/number...
best of go nissan , as most time aftermarket will be shorter or longer anywhere from 5-15mm depending on belts and then you will have problems with instaling the belts
nissan will have right belts for our cars and no stuffing around , they will fit 100%
I saw the smaller of the two Gates Performance belts at supercheap for $24. I'm going to do some ringing around to see if anyone caries a larger selection.
Wow thats exceptional value considering the prices from nissan (for 350z oem). Will check out super cheap also and see what I can find. Thanks for the info.
Make sure you're checking out the Australian Gates Online Catalogue.
Go to www.gatesaustralia.com.au then click on Auto Aftermarket and finally On Line CATALOGUE - Automotive.
You might have to log in (just some basic details etc) the first time but once you're in I think you can add the webpage as a favourite and not have to worry about logging in from then on.
With automotive micro-V belts the part numbering is pretty simple. 4PK915 = 4 ribs, PK pitch (classifies the cross section and distance between ribs), 915 is the length in mm. On cars like mine, R33, they have threaded adjusters and not hydraulic tensioners you have some room to play with so don't need to be 100% on with the length. Just note some belts could have K040360 or similar on it which is the same belt as a 4PK915 just in imperial, so 36.0 inches long. There should be a length that matches the V series skylines.
Edited by Fry_33
There is no listing for an Australian part for the V35/350Z, hence the offshore link. Best call them and double check but failing that you'll have to order it from the US if you want the gates racing accesories belts
Edited by mosoto
Oh, sorry, I didn't actually check it. I'll have someone look into getting it updated tomorrow if I remember. I figure it will be the same as the 350Z so it is something that should be in there. I wonder if it's similar to any other models like a Maxima? Gates might already stock it here but it's just not linked to the V35 as an application which happens occasionally.
I just checked the Gates Australia Online Catalogue and they list the following belts for a 350Z.
Z33 (2002-08) - 3.5L V6 24v DOHC EFI (VQ35DE) - AC
Belt = 4PK945
Z33 (2002-08) - 3.5L V6 24v DOHC EFI (VQ35DE) - ALT
Belt = 6PK1170
Those part# are for standard belts yeah?
Interesting, no listing here for the micro V Performance belts: http://www.gates.com/australia/downloads/d...folder=brochure
If anyone is after performance belts : http://www.powerenterpriseusa.net/products...timing_belt.htm
you'll note the Z33 shares the same AC belt as the BNR34 as well as others.
Edited by mosoto
    • Ok so will run the piping over that radiator and no plenum it is. Put that money towards a Haltech and see what suits. Any ideas something like an elite 2000 or 2500 right? My long term goal is 300kw e85 and manual swap and that’s a dream come true. For now will be 200kw and auto the stock rb25det neo intake isn’t too expensive with throttle body. If I was to have the port matching done, Would that be better than the stock de intake as the det has bigger holes plus has the spots for sensors etc? And suit more long term?  appreciate the advice?
    • You understand AFR is not the only thing that contributes to it pinging yeah? Funnily, what the AFR gauge will tell you when it likely is pinging, is going to make you think things are really safe and good.
    • Run the piping how we all have for decades. Also the duel runners with the +T setup dramatically helps it gets on boost quicker. Yes, chase huge power it'll become a problem, but you're a long way off when you're already saying an aftermarket ECU is out of the budget. You also say NisTune as it's simple, and then immediately say it'll be painful, meaning... It won't be simple. It will likely cost you a lot more stuffing around with a Nistune, than just putting a Haltech or similar in.
    • I’ll order an afr gauge to keep an eye on it.  Then will get a haltech soon
    • TD05 or maybe pulsar PSR2867r Gen 2?  id love a garret but it’s quite out the budget for now and I’m not chasing crazy power.    yeh fuel pump haven’t looked into but whatever works, kind of last on my list.    Nistune because it’s simple but Ik it’s a lot of pain especially as I’m auto +t with the whole seperate TCM etc still investigating that. Haltech id love but once budget tight for now atleast.    finally the reason I’m trying for a plenum instead of the stock intake is I already have a standard Intercooler mounted etc. so the ports are on both sides so trying to not have to go over the clutch fan radiator etc. trying to find a good deal return flow if I don’t than this will do for now I guess. btw any ideas with that, apparently some people have to cut blades to reduce it from hitting the Intercooler piping over the radiator ? Thanks
