Hi all :D
I have only just had new turbos installed and had the car tuned. It is making a solid & safe 307kW at all four wheels on a very comfortable 16PSi :(
Other mods include:
Built Engine
Big sump
Forged Pistons
Rods
HKS 272 Cams
720cc injectors
Garrrett Turbos
Power FC D Jetro
Exedy Twin Plate Clutch
Oil cooler
Tein Super Street coilovers
Turbosmart E-Boost boost controller
Trial full exhaust
18 x 10 +18 Work XD9 wheels
Z Tune colour coded bodykit
Pioneer 7.5" DVD/TV / full stereo
Nismo 320kmh dash
Body of car has done 139,XXXkms, but motor was only built approximately 3 years ago. I have had the car for a year and have done only 5,000km-ish in that time. Car has been serviced twice in that time. I am selling with my head, not my heart - it's time to start saving money for a house.
I need to sell this car so I have dropped the price from $62,000 to $57,000!
Respond in thread, PM me, or call/SMS me on 0402 345 185.
Bec
PS I will put pics up when I am at home as don't have any on this computer (feel free to put some up if you have any :) )
https://www.sau.com.au/forums/topic/296863-for-sale/
PS I am open to the idea of an S13/Onevia + cash ;)
Hi, Bec
I am a gtr man with a collection od S15s GTR33 and GTR34, RX7 RS 2 seater spirit r type A, we may be able to do a swap!! will call you
Alex 0439 818008 Melb 3195
https://www.sau.com.au/forums/topic/296863-for-sale/#findComment-4960781
Open to reasonable offers guys, I need this car gone ASAP... A beautifully built, serious GTR!
Pics and info can be found at Carsales ad:
http://www.carsales.com.au/all-cars/privat...0&silo=1011
Edited by missbecjane
https://www.sau.com.au/forums/topic/296863-for-sale/#findComment-4978351
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
