I do have set of 4 fully adjustable TEIN coilovers suitable for R34 Skylines .In perfect condition with springs .
Rear set are with fork so maybe R33 GTR as well ?? not sure on that one .
1000$ FREE POSTAGE AUS Wide
pictures soon
Edited by familka gtr
https://www.sau.com.au/forums/topic/296872-tein-fully-adjustable-coilovers-r34/
are they for a gtr or not? coz R33 and R34 GTR should fit each other afaik? what model are they and spring rates etc?
They have fork on the rear ones so GTR as well ( correct me if I am wrong ) they are Super Street , spring rates I dont know .
where are you located bud , and do you have pics?
I am in Rochedale south,
I can make pictures of the rear's as they are already out , but front are still fitted on . but i hope will get them out in next few days .
sounds good, im around the corner so you may have a quick sale if the are in good condition.
How long have they been on the car for? and why are you removing them?
  • 1 month later...
I got them out of the car and here is some pics . I didnt clean them on purpose so You can see they arent leaking or so .They are just few thousand ks old .
  • 2 months later...
And here are photos after i cleaned them up, wanted to show them with dust etc just as they were to give an idea theres no leaks .
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
