Hi all,
Helping my bestmate sell his car..
As follows
-2002 Subaru Impreza WRX wagon in silver
-Great condition, always serviced with quality fluids (Royal Purple and Castrol)
-All work done by IS Motor Racing
-100,000 km service recently done with genuine Subaru parts
Lots of extra goodies.. as follows
Fujitsubo RM-01A cat back exhaust (street exhaust, not loud loud, very nice sound)
X-Force 4" dump pipe
MetalCat High flow stainless steel cat
MRT up pipe
In other words, car has full turbo back exhuast in addition to the up-pipe (part of the extractors sort of..) which removes the restrictive factory up pipe with cat.
IHI VF29 Turbo
STi top mount intercooler
STi bonnet scoop (same silver factory paint) and splitter
ARC Induction/Intake box (also have a spare APS in-guard intake)
Zerosport inlet pipe
HKS double fire step colder racing spark plugs
Sard 650CC injectors
MRT Billet Aluminium Injector Rail
Walbro in-tank fuel pump
Perrin lightweight crank pulley
Factory ECU remapped through ECUTEK @ MRT
GReddy Profec B-Spec II boost controller
Cusco coilovers (bought new, specifically engineered for the wagon)
Cusco sway bars
Cusco underbody brace
Cusco Strut braces F/R
Brembo brakes F/R from 04 STi
RDA slotted rotors F, DBA conversion rotors R
Bendix Ultimate pads all round
Rays Volk RE30 wheels 17x8 with Rays wheel nuts and centre caps. Wheels are a dark bronze colour. No scratches whatsoever.
New Advan 048 semi slicks..
ARC pulley cover
ARC radiator cover
Perrin radiator hoses (Black)
05 JDM STi cluster (Defi)
Defi BF triple gauge pod (Boost, Oil temp, Water temp)
GReddy turbo timer
STi floor mats (they were cheaper than the WRX ones lol)
STi front grill
Mesh foglight covers (black - unpainted)
That's roughly what's on the car. All installed. Please note almost all stock parts will come with car too, and some uninstalled aftermarket parts too such as Perrin Silicone turbo inlet hose, a unichip to suit the car. And a few extras such as roof racks (Subaru) and some other small unused parts.
I can personally attest to the car's performance. It really moves, the brakes are very impressive, and the handling is poo your pants scary good. The best thing is there's not much turbo lag as you can tell from the mod list that the car has been setup to be balanced and have as little lag as possible while still making good power (hence a VF29 turbo upgrade).
24K as is, or 19k without the wheels and brakes (factory items refitted).
Any questions, ask me!
More pics as i get them.
https://www.sau.com.au/forums/topic/297118-fs-02-wrx-wagon-hardcore-streeter/
Just asked, 130xxx odd km's, mostly motorway driving.
Still have original cluster and the jdm sti cluster was bought with very low km's on it.
Also please note the major 100,000kms was actually done a fair while ago now. The first post info was mostly copied and pasted (from an EOI ad long time ago).
Forgot another mod - twin fuel regulator. :D
Lack of interest. Its been 4 days. Some cars take 12 months to sell on here.
This rex is very nice, but have a look around what you can buy for $24,000 on here.
I'll offer my R32 GTR as a straight swap if he wants. He can keep his wheels and brakes.
  • 1 month later...
Hi Albert,
I asked my mate to confirm, and he's not really interested in an R34 sorry :). Thankyou for the interest though. GL selling your car (looks very nice in your pics).
He's not interested in the stag, thanks and sorry.
    • Not really, but the heater box is pretty simple mechanically....if the door is one way the air bypasses the heater core and if it is the other way it goes through it for warm air.  If you are sure the actuator you moved manually is for the heater mix (there would also be one for output air direction) then I'd take the heater box out and see what is happening (you'll have to regass and re-coolant the systems afterwards) BTW pp724 onwards from the GTR workshop manual cover the system in good detail, it is probably worth checking. I think the IAT sensor might be a problem electrically for getting cold (if you got 24 error code not -24 it thinks the incoming air is -50c) and it covers how to test the sensor (although most likely it is either not plugged in or a wire is damaged)
    • Use the GKTech subframe bush and bring your subframe 10mm closer to the chassis. You'll need to fix an exhaust hanger to suit. One of the best mods I've done.
    • You'd really have to pull it apart further to know, it least you can be confident that the one heading to the back is not connected any more. There was once a ground on the shifter seal mount too, your head unit issue could be that simple
    • Perfect, I'll get to it this winter then at the same time as I weld on my anti squat kit.
    • Alright so my 32 only has one temperature no matter what degree you set it to. I’ve tried disconnecting the servo motor arm and moving it either direction and got no change. I’ve fixed the leak in my AC and re charged it and with it on and clutch engaged it still blows hot even though the low pressure pipe going to the firewall is ice cold. Both heater core hoses are hot while running as well. Diagnostic code showed 24 for intake air temperature sensor. Anybody got any ideas?
