schnorky Posted November 25, 2009 Share Posted November 25, 2009 hey guys somthing werid happiend to my skyline r33 gtst today it was driving fine all day filled up 20 bucks then around 20 mins later i was sitting at the light and the revs droped almost stalled, i had to rev it a bit so it wouldnt stall but at the next set of lights it was fine bit confuzed i was thinking afm is goneskies but other then that not sure what it is... it also did it somtime when i heavly pressed the gass at idle then backed off, the revs would go to 3000rpm then when it came back down it fell to the point were the car was bout to stall cheers for helping guys Link to comment https://www.sau.com.au/forums/topic/297752-revs-dropping-at-idle-need-help/ Share on other sites More sharing options...
Hiney Posted November 25, 2009 Share Posted November 25, 2009 i'd try cleaning your AFM, and check that ur BOV wasn't leaking. Link to comment https://www.sau.com.au/forums/topic/297752-revs-dropping-at-idle-need-help/#findComment-4956341 Share on other sites More sharing options...
Hiney Posted November 25, 2009 Share Posted November 25, 2009 ** sorry, ignore the BOV part, yours isn't an atmo one ** Link to comment https://www.sau.com.au/forums/topic/297752-revs-dropping-at-idle-need-help/#findComment-4956345 Share on other sites More sharing options...
schnorky Posted November 25, 2009 Author Share Posted November 25, 2009 Cheers I'll do it after work does any one else have any advice? Link to comment https://www.sau.com.au/forums/topic/297752-revs-dropping-at-idle-need-help/#findComment-4956391 Share on other sites More sharing options...
mosquitocoils Posted November 25, 2009 Share Posted November 25, 2009 Time to clean your AAC valve. Link to comment https://www.sau.com.au/forums/topic/297752-revs-dropping-at-idle-need-help/#findComment-4956392 Share on other sites More sharing options...
shyr33 Posted November 26, 2009 Share Posted November 26, 2009 My car used to do that and then I cleaned the AAC valve and it stopped doing it for quite a while. It has kind of come back now so maybe its time for another clean. Link to comment https://www.sau.com.au/forums/topic/297752-revs-dropping-at-idle-need-help/#findComment-4958296 Share on other sites More sharing options...
payback21 Posted November 27, 2009 Share Posted November 27, 2009 1. AFM faulty 2. Air sucking in somewhere between AFM and front of turbo. Check intake pipe between AFM and turbo. It will run like cop at idle and it will not idle. For all you know, the plumb back pipe to intake pipe between AFM and turbo may have come off. Its a bit hard to see all that when most intercooler piping covers alot of the turbo and intake pipe to the turbo. Check it out. 3. Throttle position sensor moved or stuffed Try these first and get back to me. Link to comment https://www.sau.com.au/forums/topic/297752-revs-dropping-at-idle-need-help/#findComment-4958956 Share on other sites More sharing options...
