Which to get...
60 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
  • Replies 88
Well, if you keep doing this, buying new cars and selling for a better or different one my bf is going to dump me so he can do the same so can you plox stop :D
anyway
get a wrx sti >.>
Im prob going to get yelled at now :blink:
Ok imma vote for 300zx
And anyway, G4 adjustable kit is only $700 delivered off ebay, new... Link
Why would you want to ruin a perfectly good car by doing this. :blink:
Put something DECENT and top quality in the car!
Its a BMW....not a bunky pulsar! :D
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
