FOR SALE
TRUST T78-33D
Manifold
External Gate 50mm
Dump Pipe
Inlet Pipe
Twin Entry Filter
2 x K&N filter
Turbo has done less than 2000km since new and made 504hp @ 20psi. Awesome setup for any GTR, just bolt on and tune.
$3800
Also selling Power FC D-jetro with Apexi Boost controller kit with tune ( computer purchased new at the same time)
$1400
Will also sell near new SARD 800cc injectors if anyone want to the full package to bolt on for a turn key 500hp at 20psi ( just add your own intank 044). Give us a call only to happy to help.
Seller: Nigel Brown
Phone: 0417 981 596
https://www.sau.com.au/forums/topic/297780-trust-t78-33d-kit-for-sale/
Sorry Guys cant pm anyone yet as i dont have enough posts. ( will keep posting questions here )
Reason for sale is going to a larger setup.
Kit was on a std RB26 and loved every psi it had to offer.
FOR SALE
TRUST T78-33D
Manifold
External Gate 50mm
Dump Pipe
Inlet Pipe
Twin Entry Filter
2 x K&N filter
$3800
$1400 (SOLD PENDING FUNDS)
Seller: Nigel Brown
Phone: 0417 981 596
Does this single set-up require the power-fc de jetro? i have power fc with z32 afm an all the good bits, was curios if that mattered? an also it wasn't a lag monster was it? wat rear housing? wen was full boost? im running a fully built rb26 tomei engine basically wit gt2860 -7 :S they aint gonna cut it but if you could answer those questions you may have yourself a buyer :)
Bye the way nice engine bay mate!
Does this single set-up require the power-fc de jetro? i have power fc with z32 afm an all the good bits, was curios if that mattered? an also it wasn't a lag monster was it? wat rear housing? wen was full boost? im running a fully built rb26 tomei engine basically wit gt2860 -7 :S they aint gonna cut it but if you could answer those questions you may have yourself a buyer :laugh:
Yes the Trust twin entry suction pipe was designed to fit directly onto Z32's and run a power fc.
Turbo was building boost by 4K and pulling hard over the mid 4K region. Did vary a little and felt more responsive down low when under high load. Those figures where from straight line driving. Turbo never drops off boost between gear changes and was a great setup on some tight and flowing hills roads.
Not sure what housing size is as the numbers on the exhaust housing don't correspond to anything that makes sense, but ive gotten these numbers from the ID tag.
Make: T78-33D
Serial No: B276501
MFD No: 49175-02020
Hope this helps and it will be a very strong setup on a built engine, and thanks for the kind words on the engine bay.
Cheers
Nigel
Hey Mate, i will speak to my mechanic today, being monday the 13th an see wat he says but is it possible to grab your phone number? currently overseas in iraq atm that is all but i am from perth car is currently bein built as we speak an would be an interesting upgrade whilst the engine is out, so im interested but i will have to get back to you asap after i ring my mechanic.
Cheers Korey
Cheers Korey
So now i feel like a dick lol, seen ya number will give you buzz first thing monday morning 14 dec, you should have an answer buy the end off that day mate!
Cheers!
Cheers!
if nigel doesnt answer dont panic , i think he is overseas too atm ,
ps ive been in this car and its a weapon !!
Thanks Marty (mxracer),
I'm currently in China for work till the 28th of this month with no mobile coverage.
Please PM me or add to the post with any questions and ill keep you all informed. Turbo will be available for pick up or post from the 29th.
Turbo is sold to a Perth buyer, but i cant confirm this until i arrive home.
Thanks
Nigel
Ok so does this mean that everything bar the turbo would be avaiable atm? cause some1 bought the turbo itself? i guess ill have to wait to you confirm it or not.
an my car is a weapon to lol
Thanks
Nigel
So if the turbo is sold would you be willing to sell the remainder being the:
Manifold
External Gate 50mm
Dump Pipe
Inlet Pipe
Twin Entry Filter
Cause i will snap them up as soon as you arrive to australia without a doubt!! My mechanic says it will be perfect an on my built engine will push numbers beyond 600hp at the wheels, but if the turbo is sold that is no probalem still the remainder like i said above is more then ample.
Cheers Korey
  • 3 weeks later...
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
