Okay so I was in Karrinyup shops and some c$&t reversed into my r34. Dented the front bumper and a little bit of bent metal underneath.
Does anyone know where I can source another bumper and about how much it will cost? Extra points for a rocket propelled grenade launcher and 4wd tracker system -.-
https://www.sau.com.au/forums/topic/297938-carparks/
Could be a good chance to buy an aftermarket front bar, get kitted up? :)
Seriously though, that sucks, i hate people that do that. Fair enough it might happen some time (if you are fail at driving), but at least leave your details :P
You could try and fix your front bar, doesn't sound too hard. The clips you can get from Repco, and i just used a fiberglass repair kit on mine to fix up the holes. Painting is easy as, i repaired and repainted my front bar and rear bar, looks better than new :D Could you not just bend the metal back around so that it lines up with the hole again? Doesn't have to be perfect, just so it works. Don't know where you could source one of those brackets from...
https://www.sau.com.au/forums/topic/297938-carparks/#findComment-4958774
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
    • More so GReddy oil relocation kits, sandwich plates, etc. all use 10AN fittings. And same, I've only used 10AN and my car sees track work (circuit, doing laps, not 10 sec squirt business).
    • street use or race track, what hose size and why? what factors change with the hose size options ?   see most comon is an10. when you see most oem external coolers are closer to an12? does high volume oil pump like nitto need an12 or 10 be just fine
    • The rod I was moving left and right you can see looking from the passenger side floor up into the center console.  IMG_8095.mov
