Hey fellas, I decide to sell my bride material, it's 100% brand new, was going to wrap my back seats and carpet, but I got recaro front seats so it's gonna be messed up a lil bit.
Measurement is 160cm x 260 cm = 4.160 sqm
I paid $130 each square meter, so it comes to $540 before shipping.
Throw me reasonable offer and we'll go from there, stupid low-balling offer will be ignored. Please discuss offers via PM.
Or you are welcome to text me 0433552745
I live in Melbourne, inspection upon purchase is very welcome.
Willing to post at buyer's expense.
Cheers,
Gerald.
https://www.sau.com.au/forums/topic/298153-bride-material/
    • Thanks for that mate always a good help
    • It's not really a calibration issue, if the voltage is really at 2V. If the voltage is 2V, then that's what the TPS is putting out, and the Haltech is seeing that and 2V is about 40% open (you know, between 0.45v being closed and something close to 4.5V being fully open). So, that would suggest that the TPS is maladjusted, on crooked, something something something. Or a wire problem.
    • Hi guys my TPS voltage is reading over 2v at idle.  My Haltech ECU is reading around 40% throttle position at idle also which is really strange. Note the actual throttle position sensor is brand new…    anyone have any experience with this or know how to calibrate it on Haltech ?
    • The OEM disk will not work on any AEM ECU, you need to use the one they made. You shouldn't have to flip the CAS or whatever you were describing, if you set the ignition sync offset correctly it can't backfire. Make sure you're using a spark plug lead on coil 1 instead of the timing loop to avoid weird issues with the timing light. Double check that your timing settings are actually correct, like is the 24 tooth configured correct or should it actually be 12 teeth for 1 crank revolution? I also found this: 305817248-AEM-Undocumented-Settings-v1-2.pdf
