Well I joined up a few months ago but I never got around to posting up on here.
When i first go it
RB25det with broken piston ring
cut springs
stuffed lsd
What I've done so far
Engine
RB25/RB30
RB25det s1 head
NA RB30 bottom end
Greedy style plenum
Stanless high mount
38mm external gate with 6psi spring
T04z with .86 rear housing now going gt3540 with .82 exhaust housing for quicker spooling
intercooler
custom short piping, 2 1/2 inch hot side and 3 inch cold side
3 inch exhaust
50mm alloy radiator
Boosh 044 fuel pump
Surge tank
R33 intank pump feeding surge tank
Driveline
RB25det gearbox
Extrame cushin button clutch
custom on peace 3inch 3mm thick tail shaft
3.89 Weldy now got 3.7
Suspention/Brakes
Front: R34 4potters on 310mm rotors
whiteline springs and kyb shoocks
front nolithain bush kit
Just scored a jap inport steering rack wich are a quicker ratio
Rear: r33 gtst front struts with a coil cut off them on modifyed mounts
Full nolathain rear bush kit
Interior
Both buckets seats installed now
Timex gauges- Tacho/speedo, air/fuel, boost, oil pressure, water temp
Speco gauges- fuel leval, volts
sound deading stripped from the front of the front seats back
stripped boot
Mods in the near future
remaped rb20 ecu and z32 air flow meater
turbosmart boostcontrolar-got now just gota install
s13 extra lock spacers for inport 31 rack
nolithain rack mount bushes
rose jointed caster arms
brass streering sfaft joint to replace shit ruber one
The car
Old set up low mount T3T4
Started moving wires, staring to work out new turbo set up, New taillights and bushes and a few other bits
https://www.sau.com.au/forums/topic/298196-lawlers-r31/
  • Replies 43
Well it has front wheels on it for the first time in 5 months lol. I fergot how much it needs lowering more.
Started doing more to the wirring and that then strated thinking its to much efford but Ive already started so may as well finish it
https://www.sau.com.au/forums/topic/298196-lawlers-r31/#findComment-4970760
well did some more and found even more to do then toke random photos
drivers side relays
Jacked it up to take a photo for a mate off the 33 front struts and a good time to grab a photo of the bushs
this is the full suspention drop bearly higher than standard
Next bit of wirring to move the harrness is gona run in the iner geard then out a hole with a rubber gromet next to the brake hose
https://www.sau.com.au/forums/topic/298196-lawlers-r31/#findComment-4975252
Well had some spare time yesterday and went and started getting some price for the rest of my suspention/steering set up first lot of price I havnt had a chance to shop around yet but heres what it is so far
Nolithain steering rack mounts $44.95
Nolithain steering joiner $66 (but i Might just make a brass on up)
S13 Tien Tie rods, rack ends and extra lock spacers $250 (to go on my inport 31 steering rack)
Whiteline strut brack $240
Whiteline front swaybar $220
Whiteline rear swaybar $240
5kg springs for rear of Bi6tim $300
Just gota get some price on S13 to camber top
And rose jointered caster arms
Also Just after appionons on my idae for my exhaust.
Ive gota get the dump pipe re-done for the new turbo due to being high mount, diffrant flange and also wanting to get ride of the guttered cat thats welded it to the exhaust so I was thinking of going 3.5" off turbo to about half way along car or to diff (depends ont the price) then merging it back into the 3" fot over the diff and aslo so i can keep using my Redback muffler.
In thery when the exhaust gasse first come out of the turbo they are the hotest and as they flow under the car they get cooler there by shrinking so the 3 inch would be suficen will the 3.5 would flow more when the gass are still realy hot
https://www.sau.com.au/forums/topic/298196-lawlers-r31/#findComment-4987585
Well I finaly went and picked up a few of my other gauges so thought I would sit then in the cluster and start working a few bits out with it. Ive just gota take my the colum bits out so I can work out were to put the velcrow for the remotes for the Gauges. This is only a dumby made one thats why its only clear perspex
Edited by lawler
https://www.sau.com.au/forums/topic/298196-lawlers-r31/#findComment-4993468
nice nice gages man sick,
now with the exhaust larger is better with turbo car, but most only run 3inch etc, so yours going 3.5inch all the way to the muffle/box/cannon 3inch should be fine.
It wouldnt be a noticable difference but maybe a dyno difference, not enough to get upset on buddy,
When you ordering the steering and busshes??
how u going with s13 camber tops??
https://www.sau.com.au/forums/topic/298196-lawlers-r31/#findComment-4994241
Haven't ordered or worried about getting more price due to the facted that I dont start my new job until the first week of next month. so once Ive paid back the money into my investment account of what Ive used while I havnt been working Ill be looking a bit more then
https://www.sau.com.au/forums/topic/298196-lawlers-r31/#findComment-4994270
bump*
hows chrissy break going, any new pressie for ye red beast?
Na havnt even seen the car sence my last up date. hopfly new parts will be ordered after I start my new job and pay my dad back the money I owe him that Ive borrowed the last 2 months while I havnt been working
https://www.sau.com.au/forums/topic/298196-lawlers-r31/#findComment-5000976
Well br33nt gave me the encoragment I need to go do some more work but I didnt end up getting much done due to getting side tracked on a mates car
Well I pulled the turbo off to drill and tap the fitting for the waste gate line and got bord and started polishing the compressor housing. only toke one photo so far when I first toke the housing so will take photos tomorrow when I drill it and how the polishing is going
https://www.sau.com.au/forums/topic/298196-lawlers-r31/#findComment-5002173
hahahhaha love that vid man, peels fair hard, cant wait to see wat it does with its new build :D
ahhh thats cool dont get into debt over cars lol, lets say this time next month ull be pretty on par to restartin the build ye??
ive been thinkin bout polishn my new turbo housing too, is it as easy as undoin the bolts on the back and take it off?? wont hurt it??
https://www.sau.com.au/forums/topic/298196-lawlers-r31/#findComment-5002804
    • I am getting the same issue. Did you resolve it? I just got it after installing my new super coppermix and literally the same issue, new fork, new 18mm carrier, release bearing that came with the kit and replicated the exact same sound.
    • If you like - I have the STL files so I can email em. There's a couple of gotchas (i.e the holes are not threaded so you might need/will need) to utilize some M3 melt-in threads for some of the points. However if you want to be super accurate, and are willing to remove your calipers and your SHOCKS it's a really good tool. You also might need to scale the part that measures the tyre width a bit wider. It defaults to a 7.5in tyre and I mean who is running that. Luckily with the magic of CAD this is very easy to rescale.
    • jeebus. glad you weren't under it while performing the stunt. Also thanks for the link to the wheel measurer, exactly what I needed
    • In the older stuff there were very significant differences 2wd to 4wd, for example Stagea had strut front end for 2wd and double wishbone for 4wd so it was not minor to swap. From poking around the 2wd v37, it *looks* like it might be more possible; some of the parts specifically have "2wd" stamped on them which suggests the platforms are more similar. You'd still want to start with a 4wd half cut to swap stuff from though. I'd suggest if you don't have a tune on the ECU you don't really need one on the trans either. Throttle mapping is in the ECU side (and you can always use a Roar Pedal if you want the throttle to actually respond to your foot), and really if you are happy with the stock power you probably accept the stock trans behaviour too....its all made to be "sporty" not racey.
    • So, updates. I have not washed the car since it came back from Tassie. I've driven it around a bit but not got around to actually sorting it out. I DID raise it because I cracked the rear bar leaving a hotel which was very distressing. Interestingly, the car drives more compliant now that it's raised a fair bit (5mm front, 15mm rear). Also noticed that my FR height was 10mm lower than FL. So that's now sorted out, too. I also bought this and had it printed: https://www.etsy.com/au/listing/1576422240/wheel-and-tire-fitment-tool-universal?ref=shop_home_feat_1&dd=1&logging_key=08f604d9fa4cc383550ba985e6ac85cd5cac7fbb%3A1576422240 Now, if I was smart I would have taken my brake calipers off to actually use this correctly but it was evident enough to me that in the region where the caliper was... there was nothing to hit suspension/guard/arm wise. So I'm going with "it'll be fine" after using the tool to hopefully very precisely measure the wheel clearance. Also while doing this, I had the very VERY bad idea of jacking one of the wheels/suspension arms up while the rest of the car was on jack stands. I did this to see how the arm would travel. This all was well and good until the car slid off the stands and went through a fence. So don't do that. Incredibly nobody was hurt and there was only minor damage to the rear bumper as the car didn't have far to slide, and had 3-4 wheels on it. The only damage turned out to be the fence itself which was easy to fix, and a little bit of damage to the fibreglass rear bumper trim. I had already planned to try a touch up paint kit to fix the time I drove into my garage door to see if it'd help in the interim before I get it fixed properly. I used the Dr Colorchip kit after looking online and seeing everyone talking about it. Yes it's made for chips and not huge broken missing pieces and I'll be 500% recommending it for stone chips after using it for stupid things like me. This took about ... 10 minutes and looking at the half assed photo the 30 second job I did on the bumper corner was almost perfect just by using the tiny little brush and painting it in. The sealact stuff to remove over-painting is really useful, so if/when I do it again I'll likely slather the touch up paint well over it and then clean it up with the cleaning solution. The wheels should arrive in a couple of weeks. I am still kinda confident after doing a stupid amount of measuring (and borrowing a set of 18x10.5+15) that they will not fit because I overlooked something, somehow and flew too close to the sun. ALSO R34 GTR guard liners do not fit on a GTT. I bought the undertray brake duct guides and had the wonderful problem of them not fitting my intake, my oil cooler and the liners themselves were even worse. Attempting to fit them won't work in general - You would have to cut them up as another poster mentioned as the bodywork is different on the GTT. At least I can try to resell them. So instead of cutting those up, I cut up my old already-cut-up GTT liners and extended them by using some PP plastic and drilling some 8mm holes for some nissan clips for the 'extra' bit. Because I was happy to cut them I was able to mount them pretty damn forward so I now have some semblance of guard liners, and the brake vents seal the bumper from the bottom. It sort-of-looks like this, to give some idea - If you look at the GTR and then the GTT this is when I realised that I needed to seriously measure as the inside of the rim area is entirely, entirely, entirely different and could not take any internet measurements for granted.
