1994 Nissan Skyline R32 GTR. Last of the R32 GTRs to come out.
Purchased October 2007, handpicked and imported from Japan (First owner in Australia).
Immaculate condition, no rips, tears or fading on the seats or steering wheel. No broken vents on dashboard.
Still has the original paintwork.
62,000kms.
Burgundy.
Rego until October 2010.
Done 10,000kms since purchased in 2007.
Car does not come with personalised number plate.
Major service carried out at 58,000 kms replacing all oils including gearbox, diff, transfer case, brake fluid and engine oil.
Dynoed on Dyno Dynamics with 280.6kWs at the rear wheels.
Modifications:
Spent more than $15K for all the mods which were bought brand new (most of the mods have only been in the car for approximately 3000kms)
  • Alarm with SMS paging
  • Tracking device fitted – needs subscription and monthly payments
  • Tein super street suspension
  • Apexi pod filters
  • Alpine head unit (USB hard drive compatible)
  • Clarion splits at the front
  • Kenwood Amp running a clarion sub
  • Power FC with hand controller
  • Blitz boost controller (Dual Solenoid)
  • Cusco strut braces front and rear
  • Nismo super copper mix twin plate clutch
  • Grex oil cooler with relocator
  • Ferrodo DS2500 brake pads (front)
  • Work XD9 18x10 wheels with Nankang 265/35/18 rubber (No gutter rash)
  • Garrett 2860R-7 turbos (stock turbos available – from the condition of the stock turbos the car was not thrashed).
  • Sard 700cc injectors
  • Greddy cam gears
  • Greddy belts
  • Greddy clear cam cover
  • Nismo fuel pump
  • Nissan water pump and bearings
  • Spark plugs replaced recently
  • 4WD switch installed (so you can run on rear wheel drive mode)
Work carried out in a reputable workshop in Melbourne.
Receipts and most of the original parts available on request.
$25900 ono comes with RWC
Genuine reason for sale
Contact Las on 0422975657
  • Replies 44
if this is the one ive seen on bergins rd or @ knox city, then this is in immaculate condition, really nice gtr
Thanks mate
You've probably seen the car at Knox a few times
  • 3 weeks later...
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
