How to convert AVI to DPG with Leawo AVI to DPG Video Converter?
DPG is a special video container format for Moonshell, the homebrew multimedia player run on Nintendo DSL player. By converting to this dedicated format, all kinds of videos can be smoothly played on NDSL player. This guide will tell you how to convert AVI to DPG format in only 5 steps.
Step 1, download Leawo AVI to DPG Converter from this link. Be sure to install it on Windows NT/2000/XP/Vista/Win7. At the end of the installation, there will be an option to install an additional K-lite codec pack. Because the codec pack is for a better and stabler performance of the program, we recommend you install it as well.
Step 2, gather up AVI files and put them in Leawo AVI to DPG Converter. The files can be drawn directly from the file browser into the program. After import, you are allowed to organize the files in a desired processing order. It is possible that you may assign a new name for output. If you want to confirm the files, just double click on the file name to get a preview.
Step 3, there are several profiles for DPG conversion in Leawo AVI to DPG Converter. Select the one that matches your player best. If you feel the default profile is not good enough, you can open the codec setting panel via "Settings" button to suit your demands. You can save the changes for your own use as well.
Step 4, options are provided to enhance your video after conversion by Leawo AVI to DPG Converter. They are Effect, Trim, Crop, Logo and Text in the Customize panel.
Audiovisual controls like brightness, contrast, audio volume, etc. are found in Effect page.
Video time length control is found in Trim page.
Video screen size control is found in Crop page.
Image watermark control is found in Logo page.
Text watermark control is found in Text page.
Step 5, click the start button to start the conversion process. In the process panel, you are presented with the task progress, the estimated working time and file size. The process control is fully operational in Pause, Skip and Cancel. If you are stuck in a long conversion process, you will find the after-done actions very helpful.
Here you can download this Leawo Video Converter freely here.
http://www.leawo.com/leawo-video-converter/
https://www.sau.com.au/forums/topic/298475-convert-avi-to-dpg-format/
