please read the forum rules....
are you a mechanic? if so you would know what effect synthetic oils have on the cylinder walls.
Secondly the car had mineral based oil when i purchased, therefore you would understand that you cannot change to a synthetic as it can cause the motor to burn oil. Yes synthetic oils have more thermal resistance and dont need to be changed as much, but how long do you keep your oil in? And XLD is not $12 - it may be cheaper than other oils, but expensive is always not the most effective for the purpose.
please PM me if you have any more comments. It looks like you already have an r32 and not looking to buy one.
aye well i would buy but i dunno...u take aprt plan payment...i got a 91 honda civic sedan....pics r below on the link...i dunno if ure interested, i can take stereo out if u want....but i dunno wether u want it or not, well this is the car i wnt (blck/gry r32 gtst with gtr kit) n well i still cant afford it......
well speak to u l8as
http://www.skylinesaustralia.com/forums/sh...ead.php?t=32895
Still not sold.
Got to say im not sorry coz i wouldnt mind buying it, but the bank disagree with my plans and want tax docs that are not ready yet. Ohh they shit me.
Got the aircon an that lil scratch fixed yet?
P.S that stereo pumps!
thx gtrboy - im really after a turbo or a v8 if i go or a trade tho
adam: no worries i havent really been pushing the sale, its been in autotrader, quokka and s/times once each. The aircon compressor finally came on tuesday, so i will do this on the weekend if i get the time :D
  • 3 weeks later...
Quick question, what do you guys mean by plates? Do you mean the actual License plates themselves or something else? (sry not from australia, so don't know the lingo)
yep the license plates
still 4 sale $17500 firm
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
