Hey people I'm looking for R33 GTS-T coilovers, height and damper adjustable preferably.
Something along the lines of Tein Superstreets.
Let me know if anyone has anything.
Thanks! :D
https://www.sau.com.au/forums/topic/298614-r33-gts-t-coilovers-wanted/
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
