  • Replies 102
Posted Images
All parts off an 1989 R32 GTR with minor front end damage. Located in Adelaide. Willing to post at buyer's expense. If I haven't listed an item u are looking for, ask.
Engine/Mechanical
Plenum & Throttle Bodies $300.00
Standard Block $700.00
HKS 2530 Turbos approx 10,000k's old $2,000.00
Exhaust Manifolds $50.00
AC Compressor $120.00
Power Steering Pump $100.00
Alternator $50.00
AAC $50.00
Coil Packs x6 $100.00
Ignitor $50.00
Covers (minor crack on front cover) $300.00
Crank Pulley $100.00
Turbo Oil Water Lines $50.00
CAS $120.00
Tomei Camshafts $500.00
Greddy Cam Gears x2 $200.00
Windscreen Wiper Motor $40.00
Brake Master Cylinder $50.00
Clutch Master $50.00
Boost Sensor $30.00
FMIC Piping x4 $80.00
BOV x1 and adaptor plate $50.00
Cross Over Pipe $50.00
AFM's x2 $140.00 (2 Sets)
HKS Pod Filters and piping x2 $80.00
Gearbox $500.00
Front Diff/Sump $300.00
Power Steering Reservoir $30.00
O2 Sensors x2 $50.00
Engine Wiring Loom $200.00
Injector Resistor Pack $50.00
Fuel Rail $40.00
Clutch and Brake Pedal $30.00
Accelerator Cable and Pedal $50.00
Windscreen Washer Bottle $30.00
Front Driveshaft $40.00
AC Condensor Fan $20.00
Standard Clutch Fan $40.00
Starter Motor $100.00
Interior
Dash Cluster 280kph (No Brand) $150.00
Front Seats (wear on driver side seat) $500.00 (pair)
Rear Seat $100.00
Momo Steering Wheel & Boss $50.00
Instrument Cluster Surround $30.00
Door Cards $60.00
Dash Loom $100.00
Carpet $80.00
Roof Trim $80.00
Center DIN Guages $80.00
DS Window Control $60.00
Sun Visors $30.00
Boot Trim $50.00
KickPanels $30.00
HICAS Computer $50.00
Gearshift Surround $40.00
Center Dash Trim $40.00
Rear 1/4 Trim $40.00
A Pillar Trims $30.00
Center Console $60.00
Door Garnishes $50.00
Interior Lights $30.00
Dash Windscreen Demister Vents $20.00
Glove Box $30.00
Fuse Box Cover Interior $30.00
Drivers Footrest $20.00
Heater Unit $40.00
Climate Control unit $80
Suspension & Brakes
Brakes & Rotors $500
Front Driveshaft $100.00
Brake Booster $30.00
ABS $180.00
Tailshaft $150.00
Steering Column $150.00
Steering Rack $150.00
Exterior
Passenger Side Headlight $120.00
Boot $100.00
Passenger Guard $100.00
LHS Door $130.00
RHS Door $130.00
Windscreen with RVM and in built antenna $200.00
Rear Window $150.00
Sideskirts $50.00
Wiper Arms $30.00
Fuel Tank $150.00
Tail Lights $50.00 each
Genuine GTR Rear Wing $100.00
Passenger Indicator $20.00
Rear Bar $50.00
Cowl Pane l $40.00
Reverse lights $30
Clutch lines $40
Side mirrors $50 each
Rear Bumper $80
Prices on some parts may be negotiable but within reason.exterior parts factory silver. Any questions, post or pm or email [email protected]
Remaining pics are on their wa. Let me know if you want anything specific.
do u haev the interior panel for quarter windows?
plz email me at
[email protected]
interested
  • 1 month later...
  • 3 weeks later...
  • 3 weeks later...
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
