Fs: Complete Stereo System - Head Unit, Amps, Sub, Speakers Etc
Great stereo, very loud..
Comes complete, what ever i have pulled out of my car is there.
All the wiring, fuses, speakers etc..
- Pioneer Mp3 player - DEH-P6750mp with remote (think i still even have the box)
- Boss 1000watt 4 channel amp
- Avantgarde competition series amp 2 channel, 400watt
- Kenwood 6x9 260watt 3 way speakers
- Pioneer 160watt tweeters
- Kicker ES Competition Sub with professionally built box
- Raizin Volt stabilizer with wiring and connections
- FULL wiring, which includes all battery cables, ground cables, remote wires, speaker wiring (which is all the expensive thick wiring), fuses for the battery cables.
Tweeters have about 5 meters of wiring on each.
Was in my VL for about a year, but didnt drive the car much, so has prob only had about 2-3 weeks use. ;)
Not to sure on a price, owes me nearly $2800 so i will start with $1000.. But open to offers.
Prefer to sell complete..
Sounds unreal, so loud and VERY clear..
PM me if you want contact details.
Thanks
Sam
  • 1 month later...
  • 3 weeks later...
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
