any one know where you could buy a 40cm Neon light? in sydney! thanks!
You want Neon's? Pm MELV he does real neons, and is in gold coast, i know it's not local but is worth the short wait, he is a forum member, keep it in the family! :jump:
https://www.sau.com.au/forums/topic/29976-40cm-neons/#findComment-609398
ahehahehae okies...
npz...
umm.. i tried a few places they only got like 10cm
30cm and 60 and in the meters of some what so yeah..
I don't know what you just said,............ but you sound like I feel! So that said I'm going to bed now! :alcoholic
https://www.sau.com.au/forums/topic/29976-40cm-neons/#findComment-609434
    • I think he was only proposing to use the wire, not the sender. Simply because it runs from the right place to the right place. Personally, I wouldn't hack up the factory wiring like that. I'd just lay in the Defi loom.
    • From memory it wasn't too hard to simply see which wire ran where when you plug that in. Unfortunately also from memory the OEM sender does not use the same configuration 99.9% of gauges run. So in other words if you connect the signal wire that was running to the OEM gauge to your DEFI gauge you might find your oil reads at 200C or some other incorrect value. I remember having the same line of thought and then running new wires/senders to match the gauges I have. The pinout is available in the R34 workshop manual.
    • Does anyone on here know which wire on the GTT triple gauge pod harness is for the oil temp gauge? my sensor works fine but I upgraded the gauges to DEFI advance. And if I can simply piggyback off the oem oil temp wire to the Defi oil temp sensor wire that would make life so much easier.
    • Even face her a wash now that’s it worth more than my house
    • This was what I was invisioning, or Pete cutting a beer can up and hose clamping it around the catch can! Ha ha ha
