I'm just after an alternator belt or can I buy a similar one from supercheap, autobarn???
head down to repco or similar that deal with bosch belts.
ask for:
Alt 4PK880
A/C 4PK925
PS 4PK955
there around 8bux ea so if 1's shagged the others will be close so may as well do them all.
Hey mate I wouldn't even waste my time trying to find parts, Nissan dealers here in Aus ream you up the ass..
PM me what you need and I'll get it from Nissan Japan for a fraction of the price of what any Nissan dealer here in Aus will do.
And I'll back that statement!
Got a quote the following part numbers? I'd be interested to know the difference - transfer case clutch packs no. 3153205U00 and 315361P400.
If you can find the following I'll definitely consider buying them from you- 31346-05U00 and 31347- 05U00 (oil pump drive gears for transfer case)
they are all connected
if one dealership doesn't have parts it will get them in from the closest place, which quite often is melbourne which means they will be there the next day
if they have to come from japan it takes like 10 days though mine came in 1 week
no matter what dealership you ring, they can get you any part you want
i don't understand why you didn't pick the phone up first
Edited by mystery_kid
I am away on XMAS holidays, PM me and I can help you when I get back, PM is the quickest way to get me!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
