I'm changing all my brake rotors and pads this weekend so I thought i'd clean up the calipers and maybe repaint em.
So far im going with a metalic red color, really just w/e red i can find.
But I'd like some ideas on colors that would go well with my car, so far im going with a silver/black scheme (body kit wont be on for another 2-3 weeks (HTFU! :( ))
Also what prep work garantees a good job and what paint should I use.
pic of the car:
https://www.sau.com.au/forums/topic/300183-caliper-paint-job/
Hey mate, I recently repainted my calipers blood red or orange/red as it's known. Go to Repco and they will show you this colour, it's not the usual boring red, it's metalic and a tad orange - makes the car look really hot.
Ok how to get best results...here's what you gotta do...
1. Take your rims of one by one (if you only have a standard car jack) - alot of people spray with rims on - this is a no no as you cannot get to the hard-to-reach corners and it won't be a complete job...so you take your rims off and sand it down as much as you can so that there are no rough surfaces or left over bulky paint bits left...spend at least 20 mins sanding each caliper down...
2. Buy some good quality primer (the grey primer) - spray one at least and no more than two coats of primer onto the caliper allowing 35 minutes for each to dry then repeat.
3. After the primer has completely dried and has setted. Apply two coats of the colour paint, spray like 2cm away from caliper with an up and down motion moving from left to right evenly. Make sure to cover/mask off unwanted areas before painting. Allow each coat 1 hour to follow dry then repeat second layer. In my opinion, two layers is plenty as more will just make the caliper look bulky and over-painted.
4. Put your rims back on but do not drive or move the vehicle at all for 24 hours. Spend some time going through over-spray areas with a cloth and some strong detergent like petrol or paint removing liquids.
5. Get a soft piece of cloth or tissue, put some wax onto it and then wipe over calipers once. This is to remove any dirt or dust gathered to bring out the sign...then drive your car off...it's done!
I strongly suggest this blood red colour but other options which also look nice include: gold, black and dark yellow. Each to their own...Gold and black would probably be nice and subtle whereas red or yellow would be loud and 'in your face.' Depends on the look you want to project.
Good luck.
Kevin
I'd recommend at least removing the caliper and unbolting the brake line holder from the base, so you can rest caliper on the ground or on the lower control arm...then you've got a bit more mobility for sanding and painting..
Taking the calipers off altogether and dismantling them is the way to go though...then you could anodize them ?
But yeah, definitely not a fan of these dodgey paint jobs while the caliper is still fixed to the knuckle assembly....stupid half assed idea if you ask me.
  • 1 month later...
Im going to paint my calipers in the next few weeks and I am looking for a nice red colour. Spunky Munky, you mentioned about this blood red or orange/red caliper paint from Repco. Last week I drove down to my local Repco store and asked them for this colour. They had no idea whatsoever. Do you know the brand or anything that can help me show them what I am after – perhaps a picture of the paint can? Would you happen to have a picture of your result? Sounds like a nice colour.
Edited by S1LV3RTRACKS
tbh i spent ages trying to find the right paint, ended up buying 4 different cans lol!
repco/autobarn/super cheap, are usless when it comes to getting the right color.
I ended up using a firehydrant looking red on the front calipers and disks looks rly good, but im looking for a metalic red as I think it would suit my car more.
but none of the above stores stock any cans of metalic red caliper paint :(
looks like i will be paying $100 or so to get a litre of paint made for me.
but none of the above stores stock any cans of metalic red caliper paint :D
try and find a can of duplicolour metal cast, they have an anodized red that looks pretty wicked
you'll have to ring around to try and find it though, i found some at my local supercheap
I really like the look of the duplicolour metal cast anodized red. Found some at my local Supercheap at $20 a can. Need what they call duplicolour groundcoat also, so assuming one can of each will do four calipers the price comes to $40. Going to attempt painting in a few weeks when I have some free time. Was looking at the Anodize your brake calipers thread - some good information with pictures in there.
    • Onto the rear lower shock mount. It's worth starting with a decent degrease to remove 10+ years of road grime, and perhaps also spray a penetrating oil on the shock lower nut. Don't forget to include the shock wiring and plug in the clean.... Deal with the wiring first; you need to release 2 clips where the wiring goes into the bracket (use long nose pliers behind the bracket to compress the clip so you can reuse it), and the rubber mount slides out, then release the plug.  I found it very hard to unplug, from underneath you can compress the tab with a screwdriver or similar, and gently but firmly pull the plug out of the socket (regular pliers may help but don't put too much pressure on the plastic. The lower mount is straightforward, 17mm nut and you can pull the shock out. As I wasn't putting a standard shock back in, I gave the car side wiring socket a generous gob of dialectric grease to keep crap out in the future. Putting the new shock in is straightforward, feed it into at least 1 of the bolt holes at the top and reach around to put a nut on it to hold it up. Then put on the other 2 top nuts loosely and put the shock onto the lower mounting bolt (you may need to lift the hub a little if the new shock is shorter). Tighten the lower nut and 3 upper nuts and you are done.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
    • Yes. Autos typically work from the speed sensor on the pinion shaft of the diff. I also think that even if you have a proper speed sensor for the bog manual in the manual box, that the signal it outputs is not compatible with the auto dash anyway. You should consult that manual (the book, not the gearbox).
